Question about Asko Dryers
What do I need to fix my Asko gas Dryer it is showing an error code of H3
Posted by Leticia Guerra on
5 Related Answers
duby1990
Justin Duby
  • 370 Answers
SOURCE: whirlpool gas dryer doesn't run. error code pf shows on lcd
pf usually means power failure. Try to clear the screen or hit the off button to clear pf and then see if it works.
Posted on Nov 17, 2008
mastatech
mark milligan
  • 478 Answers
SOURCE: whirlpool duet gas dryer ggw9200l need error codes
There is a mini manual located inside of the machine whith the codes and troubleshooting guide on some they are on left and some are under the top.
Posted on Mar 13, 2009
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: my asko dryer needs replacing, but my asko washer
have an electrician wire in a isolated 240v outlet for the washer, or convert the existing dryer plug into an outlet for the washer (pretty easy) and go with a gas dryer if that's an easier less expensive conversion. Either that or you can purchase the materials at a local home depot or comparable hardware outlet.
too bad you don't want another asko dyer. obviously you're experience has been a bad one (or it's too small?) they are likely one of the best in my experience, but unfortunately there seems to be a lack of knowledgeable techs. to service them, as seems to be the case with euro machines in general. (no have no vested interest with asko, I just like the way they're made. ha ha).
hope that helps,
good luck
Posted on Sep 28, 2009
Tim Whalen
  • 3074 Answers
SOURCE: Hi - I have Abrams new Asko T752 gas dryer that
what is the error code? Tim
Posted on May 21, 2011
gbob59
  • 3063 Answers
SOURCE: Can I get a list of error messages for an ASKO TL751 clothes dryer?
I googled: Asko TL751 Electric Dryer Error code HI
You may find a manual in this search that gives you the code
If I had to guess it means the high heat is not working, or the high
temperature protection has opened to protect the dryer from
self distruction.
Your owner's manual should give the error codes.
No manual? manualslib.com may have it. YOu may want it next time anyway.
Posted on Mar 31, 2015
self distruction.
Mar 31, 2015 | Asko TL751 Electric Dryer
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
How to fix a strap traction failure for h3 2006
strap?
are you getting error codes to the dash or a scan tool
or is this something physically you see bad. do tell where ?
im here, seeing X, why is X like this ,show a photo of words fail.
Jun 11, 2014 | 2006 Hummer H3
Suction when I remove the gas cap
your supposed to have suction in your gas tank if your showing an evap error code you have a sensor out
Feb 11, 2013 | 2007 Hummer H3 SUV
How do I gain access to the gas valve coils on my Kenmore 80 series gas dryer?
I have a E1 code on my Kenmore H3 dryer. it runs great and then 15 mins into it E1 appears and it stops. Help!
Jun 03, 2009 | Kenmore 659 Electric Dryer
Asko 1503 error code
Hi, Sounds like a bad door switch. Here is a site that may help you. error codes... ttps://removeandreplace.com/2015/12/22/asko-dishwasher-error-codes-how-to-clear-what-to-check/ch.
Feb 10, 2018 | Dishwashers
I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
Dec 18, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
141 people viewed this question
Top Asko Dryers Experts
Marvin
Marvin
Paul Carew
peter gittos
peter gittos
Are you an Asko Dryer Expert? Answer questions, earn points and help others
