Question about Electrical Supplies
50RZ62 kohler Generator
Starts but shuts down ,overcrank light turns on,speed sensor(lockrotor is ok
sherlywang
    Master:
  • Electrical S... Master
  • 425 Answers
If you need more support or purchase diesel generator set, please visit at www.dieselgeneratortech.com
Posted on Oct 10, 2019
5 Related Answers
CarlGehrke
Carl Gehrke
  • 169 Answers
SOURCE: kohler 12kw generator starts but shuts down after 3sec
Your gas pressure is too low and you may not have a large enough supply pipe. You need at least 10 inches of water column with the engine running to operate an LP vapor fueled engine. Because the engine is starving for fuel, its governor opens the throttle to WOT (so it goes to high revs) but there isn't any fuel to make horsepower with so the output voltage falls and the undervoltage alarm trips.
Carl
Posted on Dec 03, 2008
mamicheddy
mamicheddy
  • 79 Answers
SOURCE: Hello, I have a Kohler Marine Generator that says OC on the menu when I try to start it. Any ideas?
OC stands for Over Crank. How long does it take before the genset starts?
Posted on May 07, 2009
epangan29
  • 113 Answers
SOURCE: My generator runs automatically once a week. It
disconnect the battery and try again.
Posted on Nov 29, 2009
Anonymous
SOURCE: Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Posted on May 06, 2010
delaina5
SOURCE: how do i reset overcrank
You turn the unit to the off position, hit enter twice on control board, and put back in manual, this should reset this fault
Posted on Sep 08, 2011
My epic 425 will start turning but shuts down right away
Check the speed sensor an its positioning. If its ok then the motor or the motor control board is faulty.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 10, 2016 | Epic Exercise & Fitness
How to diagnos Overcrank light
I don't think the over crank is a problem.
Why is it shutting off?
Find the owners manual to find out if there is some fault that will shut it down or it may be an engine problem like the choke not releasing after starting.
To find a manual online you will need the make and model number of your generator.
Aug 20, 2014 | Electrical Supplies
Cardiozone Club HR T Error Code SI2
see the details and fix it. God bless you
Error - "SI2 At Power Up"
Symptom:
Indicates the OVP (Over Voltage Protection) circuit on the controller is active and belt will not move.
Solutions:
  • Check for RAIL and LVS LED's to be lit.
    • RAIL and LVS ok? Replace F2 fuse
    • RAIL not lit, but LVS ok? Replace F1 fuse
Nov 17, 2012 | Exercise & Fitness
I have an older 30KW Generac SG 030 1800rpm running on Nat Gas which I bought used. It has set up for several years. I installed a new PN0830890SRV master control board I bought from the local Generac...
need to calibrate the main control board. 83089. also is it overspeed or overcrank? if the board does not see the right rpm or is blow a certain threshold it will think it has not started yet and shut down on overcrank.
Mar 13, 2017 | Generac 13,000 Watt / 13,000 Watt Home...
My 1999 Trooper stopped running while I was going 60mph Now it wont start - nothing. All that happens when I turn the key is that the all the indicator lights on the dash board light up.
a defective crankshaft sensor would cause your engine to quit at any speed....but your engine should still turn over...thats the only suggestion I have beside checking and cleaning your battery connections.sorry I can't be of more help
Jan 17, 2010 | 1999 Isuzu Trooper
99 f250 diesel wont crank
if it a standard check the cluch safety switch, i had a switch come apart on a f250 before and caused this
Apr 16, 2009 | 2000 Ford F250 Super Duty Crew Cabs
Overcrank error message
The 'overcrank' error simply means it tried to start but never actually started. It cranked for an extended period. Check the fuel and starting issues you would normally check to start the engine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Mar 31, 2009 | Kohler 12 kW Emergency Power System -...
Abs brake light comes on after driving 20 to 40 miles. Will go off after shutting off engine for awile then comes on again after 20 to 40 miles. Why?
ABS system is self monitoring.It will perform a peliminary check on itself when you first turn the key on,thats why the light stays on for about 3 secs when you first start it up. It will also perform another check on itself after you reach speed of around 8-12 mph.
For it to come on while driving it must see something wrong at the wheel speed sensors that it knows can not be correct so it is shutting itself down. It has a digital wheel sensor in each wheel that it uses to compare side to side readings. If it sees one wheel spinning faster than the other it thinks one of the wheels is locking up and it activates. Now it could be one of the wheel speed sensors is starting to go bad or it may be something as simple as one of the tires low on air. I would check all of the air pressures in the tires first to make sure the are equal and if that is ok then I would have some one hook a scan tool to it and see what trouble codes are stored in the memory of the ABS module.
Feb 27, 2009 | 2006 Ford F-150
2004 dodge durango courtesy lights.
See http://autos.msn.com/research/vip/reliability.aspx?year=1998&make=Dodge&model=Durango . Under "Brakes". It's probably the Rear Axle Speed Sensor. Easy Fix. Do-It-Yourself. Search this site or Google "Replace rear axle speed sensor 1998 Durango"
Oct 01, 2008 | 2004 Dodge Durango
Electrical Supplies Logo
143 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
