Question about Furniture
I applied watco butcher block oil and finish to a dining room table with a brush. Will it ever dry? How do I fix this mistake.
Posted by Judith Britton on
  • Joshua Crowder
    Joshua Crowder Jul 16, 2019
    Wioe it down with some good soft rags and eventually it will wear off. If you want it food safe as a cutting surface you did good. If you want it shiny and new looking i suggest resurfacing it and using poly
4 Related Answers
D. Lover
  • 17 Answers
SOURCE: What is the difference between a kitchen and a dining room table?
Kitchen and dining room tables are generally the same. Except, sometimes dining room tables are a bit larger and made out of stronger materials.
Posted on May 29, 2012
Shades Mark
  • 11 Answers
SOURCE: What is the standard height of a kitchen/dining room table?
Hi
I was looking for dinning room tables which were standard size and came upon an interesting page at Macy's. They seemed to over a variety of shapes and sizes, many of which will cater for your needs in the kitchen, or dinning room for that matter.
Posted on May 30, 2012
peter kash
  • 29 Answers
SOURCE: We have a very small dining room space, but would still like to put a dining room table and chair set there. Can anyone suggest the best way to furnish a small space like this?
The best dining room table shape for a room with limited space is a round table. You should look into finding one with an extension leaf if you have enough space to open it. Try looking for a table where you can fit more people around it by purchasing one with a pedestal base. This leaves more room for your guests legs without the legs of the table getting in the way.
Posted on Aug 09, 2012
Scott Griffin
  • 4 Answers
SOURCE: We have a large three-generation family, and during the holidays, I would really like to buy a smaller table for the kids to sit at that will be both fun for them and relaxing for us. Can anyone reco
If your looking for a small dinning room table for your grand kids that doesn't take up a lot of space you can check out Four Chairs Furniture. They are the best Utah furniture store and the best thing about them is that you can live anywhere and they can ship it to you. I was limited in space for my apartment and I found a great sofa and table from them. Check them out I know they will be a good fit for you.
Posted on May 30, 2013
Hot paper plates stick to my kitchen table. I can't sand and refinish it because it is hand painted with designs. Is there a way to put a new sealer on it and if so, what do I clean it with dail
Sounds like a water based acrylic was sprayed on top and when the heat is added it makes the finish gummy . You can brush some polyurethane on top and that will make for a bullet proof finish.Put a little bit on somewhere and make sure it doesn't raise the old finish
Feb 10, 2013 | Furniture
Aug 09, 2012 | Furniture
Hi
May 29, 2012 | Furniture
How high above the dining room table should I hang my electric chandelier?
The height you hang your chandelier above your kitchen tabledepends on the wattage of the light bulbs and the of the chandelier. If you are using lower wattage light bulbs,you should hang the fixture about 2.5 feet above the center of your dining roomtable. If you are using higher wattagebulbs, I suggest hanging it 3 feet about the table so it is not too bright.
Are conference tables and dining room tables interchangeable?
I definitely suggest using your conference room table as adining room table because all you need to do is put some placemats and acenterpiece and it morphs into a dining table. I'm not sure that I'd recommend using your dining room table as aconference table because it might look out of place in an office. Also, conference tables tend to have holes inthe center for cords or phones to be plugged in to.
Furniture Logo
375 people viewed this question
Top Furniture Experts
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Furniture Expert? Answer questions, earn points and help others
