Question about Refrigerators
I need to recharge my 1990 sub zero refrigerator with r12, but all i can find is "auto" r12... does it matter if its auto?
Tom Chichester
    Top Expert:
  • Refrigerators Master
  • 55,695 Answers
Different container
Posted on Jul 12, 2019
Testimonial: "Thank you so freaking much!!"
5 Related Answers
Joe McG
  • 56 Answers
SOURCE: Need to change the light bulbs
The light shield has two tabs, one on each side. They may be on the front or back of the shield, It fits either way. Pull the tabs down and slide the shield back and forth a couple of time and it should drop from the four pegs that hold it in place. You will have access to the bulbs. You can go to http://www.subzero.com/locator/locator.aspx?type=0&zip=02030 and find a parts distributor near you or take a bulb to the store and match it. Make sure you get the same wattage rating.
Posted on Dec 03, 2008
Joe McG
  • 56 Answers
SOURCE: condensation and water in refrigerator
It sounds like you need someone who knows what they are doing out to your house. A tech should find and repair or replace the component that leaks. A second trip should be not be needed. The fact you have mold tells me they have never properly did your repair. Mold will grow only when the cavity gets above 40 degrees for a sustained period of time. use http://www.subzero.com/locator/locator.aspx?type=0&zip=02030 or call 800-222-7820 and explain the situation and get another company to fix it right.
Posted on Dec 06, 2008
Anonymous
  • 102 Answers
SOURCE: sub zero refrig - ice forming inside
The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
Posted on Apr 11, 2009
louis_benton
  • 7 Answers
SOURCE: Sub-Zero service manual
Here is a link to the error codes. If there is a fault condition these should be flashing on the display:
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
One this to try is a hard reset: unplug and wait for a few minutes and re-plug back in. Sometime this resets the service condition and will then display the error codes.
Ice is displayed when the ice maker is turned on. Press the ice on/off and it should turn off.
Posted on Jul 30, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Sub-Zero 550 Refrigerator/Freezer the refrigerator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
Im trying to recharge my ac in my 91 nissan pickup and im pretty sure i know where the lowside ac port is but the hose adapter from my recharge kit does not fit snugly on the fitting?
Your 1991 will have R12 refrigerant in it unless it has been retrofitted to the newer R134a refrigerant. If it is still factory original then you will need to retrofit it to the new refrigerant, or see if you can find some R12. R12 has been discontinued years ago and if you can find it it is very expensive.
Aug 29, 2011 | 1991 Nissan Pickup
What type of refrigerant does a 1990 Ford Ranger use?
there are only two types of refrigerant (or normally called as freon): R12 and R134. R12 is designed for car model 2000 and below. though, some old car compressors can accomodate R134 provided that you change your auxillary fan (fan for your aircon condenser) since R134 is hotter than R12. Ask an aircon technician if your compressor can be charged with R134.
Most of the countries now ban the use of R12 since it is more harmful to our ozone.
Aug 05, 2011 | 1990 Ford F150
I need to put freon in my 1992 ford explorer but i can not find the valve for it. Can you help please.
Your 1992 vehicle is probably R12 and not R134a. Since R12 was discontinued due to enviornmental concerns, your system will need to be "retrofitted" to the new 134a refrigerant. I would take it to any auto A/C shop that you trust and have them do the work. they will need to remove all the R12 refrigerant, flush all the oil out, change the service ports, replace the drier/reciever and then recharge. Total cost for this will depend on what area of the country you live in as labor rates are set by the geographic area.
Jul 03, 2011 | Ford Explorer Cars & Trucks
I have a Sub-Zero Model 550 whose freezer does not get very cold even though the set to 10
set freezer for 0 deg and clean the coils on top . and make sure the fan up top is working . very important .. mm 550 are r12 and may be low or refergent . this is somthing you may need a service tec to ck but do the cleaning first and see how it works. mm
Sep 03, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub-zero model 532 side-by-side icing on inside panel
I would get in touch with SUB-Z customer service, they are the only company that still cares about customers
800.222.7820
They will be able to get it fixed
Jun 08, 2010 | Refrigerators
What type of freon i use for a 1990 lincoln town car?
R-12 if it has not been converted to R-134.....should be able to tell by valve on low side pressure fill tube...R-12 is getting hard to find....
Aug 09, 2009 | 1990 Lincoln Town Car
My side by side sub zero fridge has frost building up on the back wall of the refridger ator side it is about 1/2 inch thick
I had the exact same problem. It was the evaporator coil had a leak. The coil is covered under waranty the labor is not! It was $295.00 labor and $48.00 for the gas recharge.total $343.00. Hope this helps! Yes, the price was high but it fixed the problem.
Part # was 4204420
Ed
May 27, 2009 | Sub-Zero 690 Side by Side Refrigerator
Clean front of Sub Zero
Try GOO Gone in either the liquid spray or the gel. This will not remove anything like paint or things like that. You can also use this on your cars finish and will not hurt it. So you are good to go
Feb 13, 2009 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
