Question about Motorola Radio Communications
Model H270. Why doesn't it pair?
Blue light stays on
Posted by Robert Baggett on
1 Related Answer
Anonymous
  • 5 Answers
SOURCE: Motorola bluetooth H270 solid blue light after pairing
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
Posted on Feb 12, 2010
How do I pair the earpiece with a phone? I do not have my directions.
Well first turn your phone's bluetooth ON Then turn ON your headset.Wait for the indicator light to turn from red to blue. (if it doesn't turn off your headset then turn it back on) Press and hold the Call Control button until the indicator light flashes red and blue. (meaning it's starting to pair) Set your phone to find/add bluetooth device and select your headset from the list found When pairing is successful the indicator light should turn blue and your phone will confirm the pairing.
hope that helps....
2answers
My motorola n136 headset will not charge. This is my second headset with both doing the same thing. When pluged in to wall charger the blue light comes on but it is not charging. What am i doing wrong?
I dropped my 4-5 month old Motorola N136 bluetooth under my couch while activated. Took me a week to get it out, and now it will not take a charge. All I get is the red light blinking over and over when plugged into my charger. Any ideas? [email protected]
2helpful
My motorola h270 bluetooth device will not connect to my sprint lg rumor 2 can you help me solve this problem. thanks
Charge your bluetooth device fully.
when ready, turn on your phone's bluetooth software (settings/bluetooth/on)
press and HOLD the power button on your device until it blinks 3 times (or continuously) wait for your phone to see it.
Usually the pairing code is 0000
the phone should let you know when it is complete.
Good luck.
13helpful
I can't get the blue light to shut off, even when i power it off. it also will not pair with my bbery device
I had the same problem. I plugged a USB cable from m laptrop into the headset and turned the headset switch OFF. It worked normally after that, I was able to pair it. I don't recall if the power switch was "on" when I un plugged it from my car charger but maybe it doesn't like that.
23helpful
2answers
Need a passkey for the h270, trying to pair with my ps3
Most don't have passkeys, although I can't get mine to work, the passkey is 0000
17helpful
2answers
10helpful
I have a H270 Bluetooth headset. I charged it
29helpful
2answers
My motorola bluetooth h270 appears to be frozen. It won't power off, and won't connect to my phone. Whether switch is in off or on position, blue light stays on.
Put it on charging once again. While it is charging, switch it off. It should go off now. Now, remove from charging and switch it back on. Hope it works for you
The blackberry does not "see" the H270
not sure if this has anything to do with it, but I used another phone to pair up with the bluetooth and it worked. at the same time, I plugged the bluetooth into the charger and the blackberry saw it. I guess it needed to be charged.
8helpful
3answers
HBM 750 BLUE LIGHT STAY ON
I have the same model, and if you turn it on and the light stays on, usually after a flash and about 10 seconds, your headset isn't paired with your phone. You need to re-pair it with your cell phone, the code is 0000. That should work.
Radio Communications Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Sheldon Dedek
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
