Question about Ricoh Office Equipment & Supplies
I have ricoh pro c901 and i have an error sc584 what is that? i wish someone helps me in this from where can i get it's service manual?
1 Related Answer
sjparkin20
S J Parkin
  • 57 Answers
SOURCE: I am getting error code sc 477 on my Ricoh Pro C901...any ideas?
Image transfer belt overrun sensor (rear) - these can become sticky as they are above the fuser - to clear the error physically move the belt towards the front of the machine away from the sensor. line up with black lines on bed of intermediate transfer blades' assembly make sure all rollers are clean and located correctly it is ok to turn the belt around to see if that helps
Posted on Apr 21, 2017
Ricoh Aficio SG 3100 SNw service call 20200 error. Please can you help?
no country told and service is by country. as are parts.
call them and ask for service.
the manual for this device has page and end of book called
who to contact for service.
RTM?
read it yet
buy the service manual (users guide does not cover error codes)
or call for help, Ricoh.
find it here, and sold here. $12?
https://printcopy.info/?l=en&mod=pc&strSearch=AFICIO+SG+3100+SNW
Ricoh SG 3100DN error code SC 28211, what is that and how do I repair?
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/96767-ricoh-sg-3110sfnw-showing-sc28211-error-code.html
Did not report a solution, but quoting from link above:
Ricoh Sg 3110sfnw showing SC28211 error code
Ricoh sg3110 sfnw showing sc28211 error code.
In trying to Execute carriage change sp mode (3-009-002), I cannot find 'Engine setting' (which according to the service manual) supposed to be under 'Printer setting' menu from Service mode.
Can someone help on step-by-step procedure of getting to the "Engine Setting" (sp mode) menu please in case am omitting something along the line or is their a permission required?
1helpful
3answers
False door open reading on my aficio 350
Check the fuse FU1 y FU2 in the power supply board FU1 display open door Without saying as.
12helpful
3answers
Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
1helpful
2answers
Desperate!!! Ricoh AP3800C error Need to print for christmas!!!
Fuser is not reaching operating tempurature. turn off the unit. Take the fuser out and reseat it. Power it back up. Ricoh Printers Error Codes Normally there are 3 levels of service call conditions in Ricoh printers.
Level A is the highest level. Machine can not be used until code is reset. The printer cannot be operated at all. Here is a list of common error codes.
Level B: The SC might be reset by turning the main switch off and on in some conditions.
Level C: The printer can be operated as usual except for the unit related to the service call.
SC302: High voltage power supply error
SC306: Charge roller home position error
SC320: Polygon mirror motor error
SC500: Main motor error
SC542: Fusing temperature warm-up error
SC543: Fusing overheat error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
