Question about Kenmore Refrigerators
I have a kenmore cold spot model # 106.56542400. I touched the metal measuring rule to the outlet plug and now the light will not go on.
Posted by Joseph dougherty on
5 Related Answers
Master_Tech
Gary Davd
  • 770 Answers
SOURCE: Kenmore cold spot refrigerator freezer
wow you have power to the unit what about the temp control ? is it turned up?? if so is it closed(calling for cooling?) that is the place to start you can jumper it after yo unplug it to see if you dont have a meter
Posted on Jan 24, 2008
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Power to the outlet, but apparently no power at the touch pad - it is non responsive with no indicator lights on.
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch
The washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
If all the above checks out OK, replace the touch pad.
Posted on May 30, 2009
Anonymous
  • 957 Answers
SOURCE: TTR 90 wont start. Not carb. Not CDI. Plug cap?
Every component plays a part in the ignition system. Check the wiring as you go. Start at one end and move forward. You have done a lot of work so far. so you should be close. If the igniter is fine and the other components too. Then it would narrow it down to an electrical problem or no signal/pulse to the coil. See if the coil is receiving that pulse. you can use a test light for this test. Pos. will be power and NEG. will be the pulse. With light on the NEG. crank the engine over and see if it flashes. Let me know how its going.
Posted on Jun 01, 2009
Anonymous
  • 89 Answers
SOURCE: Refrigerate not working freezer not working
sounds like the relay is bad replace the relay this should take care of the problem it is located on the compressor
Posted on Jul 11, 2009
Steve Darnell
  • 117 Answers
SOURCE: I have a kenmore cold spot refriderator not cooling
Since the compressor is not hot to touch, I would bet that the relay /overload assemby on the compressor terminals are defective.This is a common problem on refrigerators that can be fixed with a few simple tools. I recommend a 3 in 1 start kit that is easy to retrofit. Start by removing cover off compressor. Read intructions on kit to hook up three wires to terminal s,r, and c. Next cut the black wire feeding power to compressor and hook to one line of kit. Cut white common wire and hook to other line of kit. Place the kit off to the side of compressor and reinstall the cover. Plug frig back up and compressor should run if installation is correct. Hope this helps
Posted on May 17, 2010
Horn goes off on cold nights on 1998 gran am
problem in horn pad..no dought..common. problem
Oct 01, 2012 | 2002 Mitsubishi Montero
Everything is working but fan in frezer everything in bottom not getting cold it is a o5 model the name is kenmore cold spot model #106.74254400 type 22tfa
If understand your problem as being a bad fan in the freezer. Take the plastic or metal panel off that covers the back of the freezer. Inside you will see a fan that is held on by two or 3 screws 10mm or 5/16. Unplug the wires to the fan and remove the screws. This is an easy fix just make sure you unplug your fridge first. Hope this helps you.
Aug 18, 2010 | Kenmore Refrigerators
May 17, 2010 | Kenmore Refrigerators
My Kenmore series 80 washer's cold outlet doesn't work
Hi, It does sound like the inlet valve is bad. If the screen inside the inlet vavle is not plugged, you will most likely need to change the valve. If you will send me a model #. I can tell you how to get to the valve for replacement.
Thanks
Vic
Jul 26, 2009 | Washing Machines
Jul 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Got a 62600 dryer and the power wont come on got power to the unit
Working with live electrical current can be very hazardous. Testing voltage output requires working with electrical current. Do not attempt this measurement without the proper tools and safeguards
To measure the voltage at an electrical outlet requires the use of a multimeter. Always test your test equipment for proper operation before use.
Set the multimeter to AC voltage. The markings may appear as VAC, AC V, or a V beneath a wavy line. Choose the AC voltage closest to the voltage you will measure. Standard current in home and businesses in the USA is in the range of 110 to 120 volts. Some circuits used for equipment such as dryers, air conditioners, electric stoves, ovens and other large equipment may use voltage in the range of 220 to 240 volts. These heavy-duty circuits can be identified by their non-standard outlet plugs.
While grasping the insulated portion of the probes (never touch the metal conductor during testing) place one probe into each of the two terminals. The multimeter will display the voltage.
Carefully remove the probes, being careful not to touch the metal part of the probes to anything or each other.
The voltage should typically test in the range of 108 to 121 volts for most circuits. If voltage is higher or lower, professional electrical service may be required.
Good luck;
Regards:
VOTIT
Dont forget to rate;
Jul 05, 2009 | Kenmore Dryers
I have a Kenmore Cold Spot Model 70192000. Having
HI, I can help you with this. It sounds like the defrost drain is plugged. If you will get me the model# from inside the fresh food section of the refrigerator, I can look up this model and instruct you on how to repair this.
Thanks
Vic
Jun 08, 2009 | Kenmore 50522 / 50524 Side by Side...
Usage How To
To measure the voltage at an electrical outlet requires the use of a multimeter. Always test your test equipment for proper operation before use. Set the multimeter to AC voltage. The markings may appear as VAC, AC V, or a V beneath a wavy line. Choose the AC voltage closest to the voltage you will measure. Standard current in home and businesses in the USA is in the range of 110 to 120 volts. Some circuits used for equipment such as dryers, air conditioners, electric stoves, ovens and other large equipment may use voltage in the range of 220 to 240 volts. These heavy-duty circuits can be identified by their non-standard outlet plugs. While grasping the insulated portion of the probes (never touch the metal conductor during testing) place one probe into each of the two terminals. The multimeter will display the voltage. Carefully remove the probes, being careful not to touch the metal part of the probes to anything or each other. The voltage should typically test in the range of 108 to 121 volts for most circuits. If voltage is higher or lower, professional electrical service may be required.
Aug 27, 2008 | IDEAL Powr-Glo Audible Voltage Tester
Refrigerators Logo
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
