Question about Texas Instruments Office Equipment & Supplies
We have a TI-5045 11 calculator. It won't print
We have a TI-5045 11 calculator. It won't print on paper anymore . Can the ink rollers be replaced?
Posted by wacres on
ellen
Staples has Porelon PR-42 ink roller which fits the TI-504511
Posted on Jan 08, 2012
Anonymous
Yes it can. Go to "Office Max" look for Porelon 11203 calculator black ink roll.
Posted on Sep 06, 2009
Calculator will not print
I don't think you'll find parts for this, however I did find a used one, buy it now, for less than $20, shipped: http://cgi.ebay.com/Texas-Instruments-Electronic-Printng-Calculator-TI-5045_W0QQitemZ160148715050QQcmdZViewItem Buying a used unit and either replacing yours or using it for parts is probably your best bet.
Sep 20, 2007 | Texas Instruments TI-5045 SVC Calculator
How do you change the ink roller in a TI 5005 ii
Replacing the Ink Roller
  1. Press the OFF button.
  2. Remove the printer compartment cover.
  3. Remove the ink roller from the right side of the compartment. Insert your index finger, nail down, under the tab on top of the ink roller. Gently lift the ink roller out of the compartment.
  4. Lower the new ink roller (IR-21) into the compartment and align the hole in the ink roller with the pin in the compartment. Press down until it snaps into place.
  5. Replace the compartment cover.
Warning Never refill or moisten the old ink roller. This can damage the
printing mechanism and void the warranty.
The full manual can be found here:
http://www.retrevo.com/support/TI-TI-5006-II-Calculators-manual/id/426ci758/t/2/
Nov 18, 2013 | Texas Instruments Office Equipment &...
How do I replace the ink cartridge?
1. Press OFF.
Feb 04, 2011 | Texas Instruments TI-5006 II Calculator
Where can I purchase a print roller for the TI 504511 calculator? On-line, Office Depot, etc? I live in Nashville TN.
Go to Staples for the Porelon PR-42 ink roller. A single pack goes for $7.49 + tax, & a 2-pack (the better value) goes for $9.49 + tax.
May 18, 2010 | Texas Instruments TI-5045 SVC Calculator
After 20 yrs. of use, it seems to need more ink. I have the TI-504511 Model calculator. Can the ink be replaced??? I can't even see where the ink pad/roll is, so I'm thinking I have to just buy another...
If you remove the clear plastic cover from over the printer you will see the print head. With the power off if you gently push the print head it will move left/right. Notice that the top of the print head moves. There should be a small tab on the left side of the top - mine has 'pull up' embossed on it. The print roller is fixed on its underside.
So yes it can be replaced, if you can find a new one
Jul 09, 2009 | Texas Instruments TI-5045 SVC Calculator
582 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Ekse
Scoee Scoffer
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
