Question about Lenovo ThinkPad X60 Notebook
Lenovo X60 Laptop blue screen error wont boot up
Posted by darrlygrant on
Ben Wabnick
  • 2,404 Answers
Try to go into safe mode by pressing F8 as soon as you turn on the laptop.
If you get into safe mode then go into system restore and choose a date when the laptop was working properly. Let it rollback to that date and reboot the computer and let it go and see if it goes back into windows.
If you get a blue screen even when trying to go into windows then the operating system is corrupted and you'll need to do a factory restore on the laptop, meaning the hard drive would have to be wiped out and the operating system put back onto the hard drive.
Posted on Aug 27, 2009
Piyush Lal
    Novelist:
  • 149 Answers
Blue Screen Of Death (BSOD Error)
that happens when some software or hardware confilct with ur system.. it wont boot up
Try to start it in safe mode by pressing F8 button while starting before windows Logo is displayed.. select safe mode & then restore ur system..
If its not solved, pls contact me back i'll help u out for sure.....
  • 1 more comment
  • mukz11
    mukz11 Aug 06, 2012
    MATE I HAVE AN LENOVO IBM THINKPAD X60 AND WHEN I PRESS F8 BEFORE THE WINDOWS LOGO SHOWS UP NOTHING HAPPENES
  • amara johsan
    amara johsan Nov 26, 2018
    Many times we faced this problem with most of the laptop i also had the same problem with my Lenovo laptop and i finally got a solution from this sitehttps://www.lenovosupportphonenumber.com...
  • Anonymous Nov 26, 2018
    9 year late , really?
    the OP runs XP and is infected, 99% chance.
    XP is 100% hopeless, if you run XP this blue screen is the least of your PCs problems.
Why am I getting this Error code: 0xc000000f when I turn on my Lenovo Flex 2-15 laptop and how do I fix it?
You need to re-install the Windows operating system using a DVD or USB memory stick, booting from that, instead of the hard drive.
See this website Windows Boot Manager Error 0xc000000f
Mar 12, 2015 | Lenovo Computers & Internet
BIOS PASSWORD
Resetting the BIOS password is no easy feat. I'm not very experienced with doing this, but this article I found might be able to get you on the right track: http://www.ja.axxs.net/unlock/
Mar 12, 2011 | IBM ThinkPad X60 Tablet PC
I turn on my laptop ad what i get is a fan error message after which it turns off what could be the issue and how to solve it. Hit the escape key and it booted up and the fan is running full time. is this...
I turn on my laptop notebook lenovo s10-2 ad what i get is a fan error message after which it turns off but thiers still power what could be the issue and how to solve it. i can not use now my laptop
Jan 25, 2011 | Lenovo ThinkPad X60 Tablet PC
When I power up IBM TP X60 tablet I get the bios password screen, a I dončt know the password. How I can remove it or bypass it ?
For IBM/Lenovo Password
there is solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net. u need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..u need to made serial port or printer port and there is software for it ...
check this site http://www.lancos.com/prog.html
Thanks
Oct 07, 2010 | IBM ThinkPad X60 Tablet PC
My Lenovo SL500 laptop won't start up! When I turn it on, it runs perfectly until right after the Microsoft loading screen, when a blue screen with an error message pops up for 1/2 a second and then the...
hit the f8 key several times while it is rebooting and go the screen that allows you boot to windows, boot to last know good confifguration, boot to safe mode, etc... screen. On this menu you will find a selection that will allow you to stop the blue screen on the error. The error will tell you what the problem is. However from previous experience I can tell you that more than likely you will have to reinstall Windows. If you haven't backed up your data and need to recover it, It might be a good idea to setup the disk as an external drive or secondary (slave) drive on another computer, copy your data to a flashdisk or other backup device, reinstall your hdd as master/primary drive, boot to cd and reinstall windows. Have fun, let me know how it goes.
Aug 26, 2010 | IBM Lenovo ThinkCentre M55e PC Desktop
I have a Lenovo x60 Tablet Computer and when the computer screen moves the mouse starts stuttering and the t messes up when typing.. also a blue screen comes up sometimes.
sounds like a loose lcd connector, or pinched cable.
the lcd connector is under the keyboard. remove the panel that has the power button on it, it should just pop off from one side to the other. the remove the 2 to 3 screws located at topof keyboard, plus remove 2 to 3 screws under laptop located in holesmarked with a big K maybe even circled. with keyboard out of way you will see the lcd cable connector, it should have a "paperclip" handle, pull it up then reseat the connector, reassemble and test.
Aug 12, 2010 | IBM ThinkPad X60 Tablet PC
Manual
All available information is here. Thanks for using Fixya!
Feb 14, 2010 | Lenovo ThinkPad X60 Tablet
Lenovo X60 laptop display has stopped working
The backlight is broken. These are small flourescent tube lights about the width of a pencil lead. You dropped the laptop and the bulb broke. It will have to be replaced. The driver has nothing to do with your problem, reinstalling it will not get your picture back.
Dec 13, 2008 | Lenovo ThinkPad X60 Tablet PC
Ibm thinkpad tablet won't boot, says insert set up cd rom which i no longer have
Hi, During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD. Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD. thanks and have a nice day J-
Dec 10, 2008 | IBM ThinkPad X60 Tablet PC
Lenovo ThinkPad X60 Notebook Logo
1,092 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Toby Lee
Toby Lee
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
