Question about Dishwashers
Potscrubber 900 Dishwasher won't drain
My GE Potscrubber 900 (model # GSD900D-03) will not drain .. this was in my house when I moved in and has worked fine (other than it's really noisy) until now. I disconnected the drain hose and it's not clogged .. what else can I check? Thank you in advance for any suggestions.
Posted by deniseo_levy on
Michael Masters
  • 6,784 Answers
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Aug 27, 2009
GE Potscrubber 900 just runs and runs, dial just sits there
Hello Debbe,
Does the dishwasher fill with water, or is full and fails to drain?
Can you provide additional detail so that we may accurately troubleshoot? Also include the complete model number. It should be etched or stamped on a plate inside the door, or elsewhere on the washer.
Thank you!
Jan 30, 2018 | GE Dishwashers
Ge potscrubber 940 dishwasher
My GE potscrubber, model GSH942 (very old) is not working, as one of its part was fumed (burned). Though the dishwasher is old, it was doing perfect job. Kindly advise whether there is any hope to save it. picture of damaged part is attached.
664ecbc5-d293-4bf8-9a26-d4eb60b56c88.jpg 3afc25c1-d149-45c7-8546-1d01d256fcd6.jpg 2ffcde17-d805-44d2-865f-843483703dd0.jpg
Aug 10, 2013 | Dishwashers
When the water drains at the end of the cycle, water drains from the bottoom of the dishwasher, around what looks like an actuator arm? not exactly what the model # is all i know is it is a GE potscrubber...
Hi, I have seen this a lot when I did maintenance work for apartment communities.The part to fix this depending on modle was $85-$125 six years ago, I would just replace it.
Mar 05, 2011 | GE Dishwashers
Looking for dishwasher manual for Model Number GSC700X01AD. GE Potscrubber 700
is this the manual your looking for http://www.managemylife.com/mmh/owner_manuals/4241/GE-Dishwasher-L0801045?brand_name_search=GSC700X01AD+GE+Potscrubber+700+ if you have any further questions or feel that this is not the right manual message me back and please remember to rank how this opinion has helped when our chat has fully concluded it allows me to help others in similar situations in the future Thanks Rick
Feb 13, 2011 | Dishwashers
What were the dates of manufacturing this model? The serial # is MR766700B, model GSD900D-03, General Electric
go to the website and type in your serial number and model number.adrian,,,,
Jul 14, 2010 | GE Dishwashers
Burning smell coming from dishwasher caustic to nose. GE Potscrubber 900. Nothing on element upon inspection. Smell more at beginning of wash cycle or when using the pot scrubber button
Older GE's had problem with drain coils over heating
Remove the bottem front plate and the coil will be on the left side of the moter and activate when the drain cycles, check that
Apr 22, 2010 | GE 24 in. GSD2000Z Built-in Dishwasher
My old GE potscrubber 700 dishwasher stopped working
moter has probably locked up TAKE FRONT LOWER PANEL OFF AND YOU CAN ROTATE ROTOR/ if itis not free and rotates easly then the motor has failed / mm
Dec 07, 2009 | Dishwashers
GE MODEL GSD900D ISN'T PUMPING OUT THE WATER. IS THERE A RESET BUTTON?
There is no reset button. The most common problems are drain hose blocked (new or plugged disposal?), or the pump/motor assembly has been leaking. Is the motor turning? GE motors will turn from the time you turn it on until dry cycle. Remove the lower panels and observe the drain solonoid on the left of the motor. The silver plunger should go down when in drain cycle. Look for any corrosion meaning you have had a leak. If so, it is probably time for a new dishwasher. The newer dishwashers are much quieter, clean better, and use less energy. The best price on a new pump assembly is around $120 plus shipping.
Hope this helps,
Ken
Oct 16, 2009 | GE Dishwashers
Water not coming into dishwasher
Without knowing the model number of your GE dishwasher, but some dishwashers don't notice when the float / float switch is stuck. That could cause the dish washer to move through all the cycles but never have water flow into the dishwasher. That would be the first place I would look. But please post back here with what you find (plus the model number of your dishwasher) before ou rate me level of helpfulness, OK?
May 09, 2009 | Dishwashers
Dishwashers Logo
2,384 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
