My DACOR plus ECS 130 covection oven light relay keeps clicking. I found the relay that was responsable for the clicking noise. If you touch and hold the light button the click stops. So I ordered and replaced the relay on circuit board with a ZETTLER part# AZ8-1C-24DF. Everything worked fine for about 24 hrs. Now the clicking is back and I feel the relay for the light switch was not the only fix. PLEASE help with a solution to finaly fix it. I do have an extra relay.
Change your touch pad. The light maintains last condition if you unplug the touch pad while on or off. The touch pad appears to have alot of trouble with respect to the other functions as well. Beware the part#s provided by Dacor do not always match what they installed on their products. Verify the style before purchasing.
I have the same problem and sent an e-mail to DACOR. A James Carlos responded and advised that DACOR could not provide DYI info because of liability problems, pure BS in my opinion. I've had problems with a DACOR microwave (manuf. by Sharp), my DACOR wall oven Model ECS103 and my DACOR Raised Vent system and told Mr. Carlos so. I don't know how to fix the blinking oven light other than cutting power at the circuit breaker panel or removing the two light bulbs which other have advised but suspect a new front control panel is required. If you find a fix, please advise me at [email protected]. I think DACOR products are overpriced and junk.
f resetting the high temp limit switches did not resolve the issue, it may be a problem with the broiler and bake elements themselves or with the wiring and connections that supply power to them. It would be best to have a qualified technician inspect and diagnose the issue to determine the necessary repairs.
Call a repair man. He will swap the control panel, it will cost you $450 and it will still be broken. He will come back and change the circuit board that has the clicking relay. It will cost you $450 and will still be broken.
I have the same problem, however I found that if I just hold the Bake, Broil.ect button in until you hear the relay click then the oven functions normally.
I have the same problem with a DACOR ECS 130 and also set the breaker panel switch to OFF to prevent the light from turning on-off or staying on. It might help to unplug the touchpad connector behind the control panel or it may be a problem relay on a circuit board. I've had the problem for several years but will start work on it tomorrow because we do not bake often at my house.
P.S. I'm not an appliance tech but have had problems with the DACOR DM024 microwave( made by SHARP) and the DACOR raised vent. I think DACOR products are junk. The raised vent problem required replacing the entire circuit board!
I found the bottom element was not getting any power by using a volt/ohmmeter and a test method described elsewhere. (Shut off power, hold down COOK TIME while turning on power. then within 30 seconds press each mode you want to test and only that element/fan/etc will turn on. Cancels by itself after 30 sec.)
I traced the wire back to the relay (wire checked good) and there was no power getting through the relay although it clicked. Removed the relay board to replace it and found a cold solder joint on the "out" terminal with obvious past arcing carbon. Cleaned and soldered the pin and the oven now works normally. WHY THE SLOW TO HEAT? The oven turns on all the elements to preheat faster and when it reaches your set temp it beeps and now only turns on the element you selected to maintain the temperature. (Bake or Convection) Our malfunctioning ovens would then cool since the element is not working properly and it must go back into preheat and keep cycling. BY THE WAY- Don't ever use 4 hours on self clean it kills the boards and/or display. I also put a house fan in front of the oven and blow it into the lower grill to take away some of the heat on the two boards. Learned the hard way!
There is a new relay board available that is suppose to fix this problem issued 3/17/05. old part number 82127 new part number 92028 I found this a dacorservice.com. ignored login slected parts at top right of screen them looked up my wall oven model number ECS and read thru the parts list
Link is http://ww1.dacorservice.com/PartsCatalog/docs/ProductModels/522/PM_RSD-101708.pdf
i found my circuit/schematic tucked inside the back panel in a envelope,
you have to remove the oven from the wall to gat to it and start un screwing the panels,
i think it was on the top.
I am still waiting to read any suggestions out there?
dacor light relay clicking
