Question about The Office Equipment & Supplies
Hello, I bought fellowers powershred SB-15C in USA. Now in Europe I need converter from 220v to 110v. But I don't know what is the power of this item. Could you help me? Thank you.
Posted by Laura Grice on
The Spaminator
    Brigadier General:
  • The Master
  • 487 Answers
Has it got a current rating on its label ?
if it does multiple voltage and current together to get idea of power rating in watts
Voltage x amps = power in watts
if current is 10 mA it is 0.010 A
1 Amp would be 1 = 110 V = 110 Watts
Posted on Aug 19, 2019
5 Related Answers
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: hcd bc150 main power
Please check Input Voltage 110 ~ 240 volts AC at rear or bottm side of unit. If same is written there, its Auto Voltage Operatable and can be use on 220Volts.
Posted on Aug 31, 2008
Avi
  • 66 Answers
SOURCE: MAKITACHARGER 220v to 110v problem after using of right converter
hi all,
I added another HowTo page for moding the DC18RA from 110V to 220V , you can find it here
Have fun and good luck
Posted on Jan 10, 2009
Anonymous
SOURCE: can you use a xbox 360 european power brick (220v) on a USA xbox 360 in europe
You must see the data on the brick label. If it says the correct tension (tension = voltage), yes, you can. But be careful because the Xbox's have three tipes of tension. It depends on the motherboard. If the mother is a Falcon, the tension is 14.2 V, but if it is a new Jasper, the tension is 12.1 V.
Posted on Mar 13, 2009
murf427
murf427
  • 336 Answers
SOURCE: Need the sb-95c plastic spur gear for the Fellowes Powershred. Where Can I get one?
Go to support on the Fellowes website. Enter your model number and you should be able to locate a parts finder. The shredders are rather inexpensive and the repair parts may not be available.
murf427
Posted on Aug 03, 2012
dmftrucker
daniel hendrickson
  • 1922 Answers
SOURCE: Whirlpool electric dryer 220V bought in USA and brought it to Europe Serbia. I was told that USA 220V and Europe 220V is not same. I did not plug it in yet can someone tell me what to do. Thanks
the voltage is approximately the same,the difference is the frequency of incoming power as power delivered in the USA is at 60 Hz. and power in Europe is at 50Hz. so some electronic parts will not operate on this frequency,you might be able to purchase a power/frequency inverter unit but not sure on this,talk to your power provider as they may have the answer to this
Posted on Dec 06, 2012
What causes the Fellowes Powershred SB-15C shredder to show that it's full when it isn't?
Check and make sure there is no paper or paper dust covering the Bin Full sensor. underneath the head.
Aug 03, 2014 | Fellowes Office Equipment & Supplies
Parts for fellows sb-97cs
Check eBay for parts or Craigslist for a shredder you can cannibalize. Sometimes Fellowes can give you the part number which can help you search.
Jul 03, 2014 | Fellowes Manufacturing Powershred SB-97CS...
If I would buy a Onkyo TX-NR616 in the US (110V) and take it Europe (220V), wouldn't it be a solution to simply exchange the power transformer for a 220v one?
An stepdown transformer is needed should you buy in US and use it Europe
However, if your on a technical side , trace the primary windings , and check
There are European versions which are already 220V, no need to convert.
Source : page EN 99 of the Onkyo TX NR616
manual
Sep 24, 2012 | Onkyo Tx-nr616 7.2 Thx Certified Network...
Convert US 220V to European 220V
all you need to do is to purchase a power converter also known as transformer that converts the European 220v to110 v, so that American appliances will operate on European current.
Dec 01, 2011 | Miele W1926A Front Load Washer
Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
Jul 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Fellowes S8-*5c
If this is actually an SB-15C I posted a solution elsewhere and will repeat it:
I called the toll free number for Fellowes Help Line, 800.955.0959, and spoke to John who was most familiar with the SB-15c. I indicated that the "bin full" LED was bad (actually the transmit bulb). After John ascertained that I had indeed cleaned the bulbs, he made available a replacement part, MasterCard or VISA required. Replacement of these bulbs is not for everyone. A level of technical ability and some tools will be required.
I have never had this level of technical support available on the first call. Kudos for Fellowes.
Feb 13, 2009 | Fellowes Powershred SB-85C Shredder
The bin is full light remains on even though it's empty. How to I get it to work correctly?
Dec 24, 2008 | Fellowes Manufacturing Powershred SB-97CS...
Can you use a xbox 360 european power brick (220v) on a USA xbox 360 in europe
If you do you will damage the internal components and it will break. Do not try it.
Apr 17, 2008 | Microsoft Xbox 360 Console
23 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Peter March
Peter March
Level 1 Expert
Bruce Showalter
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
