I have used an SMC router (SMC wireless barricade g with built in annex A ADSL modem H02.11g )for approx 3 years. For historical reasons, I have had separate phone lines for voice and broadband but now want to save money by using the broadband line for both voice and data traffic. On my wireless mac (OS X) I connect using ssh to a remote site and from there launch x-terminals (which can display graphics etc.) and I work constantly on these xterms. I am very happy with the service I get from my broadband service provider (BT Ireland) combined with your product - provided it is data traffic only! When I answer the phone on the broadband line, the xterms all disappear the next time I click on them. (If I ignore the incoming call there is no problem). I have contacted BT technical support and they claim it is a problem with the SMC router. Please help! Paddy Mc Carthy.
SOURCE: Linksys Phone Adapter with Router Model SPA2102-R Connecting to Internet
from the cable modem or dsl connection, connect to WAN on the linksys device From PC port to the computer. you will have to make sure if all the port or opened. Normally DATAONE will not block any ports but its always adviceable to check if all the potrs are opened. you will have to put your mac code on the modem. If that does not work you might have to clone your device (information transfer from modem to your device) and you should be good to go...............
SOURCE: Problems with my new TP-Link 108 wireless ADSL2+ router modem + splitter filter
sounds like you are using a splitter...does your modem run off a splitter without a dsl filter on it?
SOURCE: Sharing internet with bt voyager 210 adsl router and linksys broad band router
hook you linksys uplink you cabel out from adsl router uplink other end goes to links wan
SOURCE: re- belkin adsl2 plus wireless router
i think u have an adsl modem + router u have to connect the phone line on the back where it say. yes it can be used with other broadband services in that case you have just config it.
SOURCE: adsl modem giving very slow and intermittent internet connection
this is not a problem with ur PC or router this could be in the Filter or splitter that ur ISP gave you, what i would do is call ur ISP and have them run a line test that could be the reason
i work for att. and that does happen ALOT you can also go to
www.speakeasy.net go to the bottom you should see whats my speed or test ur speed click on that and select a server closest to you and it will run a speed test up and download speed
good luck ,
July
