Question about Magic Chef MCBR440 Compact Refrigerator
My Magic Chef Mini Fridge just stopped but the compressor is hot.
It happened last night, it was still working perfectly n when i woke up it defrosted then i turned the thermostat off and put it to "7" again but not getting cold. I hear a click then it disappears. I unplugged it , then turned it on again, don't hear a sound of it being on, but the compressor is still getting hot. The fridge is empty already and cleaned everything inside it. Plugged it , heard a click then did not turned on.
Is this mini fridge broken already, is it worth repairing or just buying another one. I just bought it in craiglist for half of the original price. The model # is MCBR445W1 white color.
Pls. advise. Thanks.
Posted by nybabeako on
fixdit4real
    New Friend:
Ok In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Posted on Jun 15, 2011
  • Full Name
    Full Name Dec 06, 2014
    I did this with the first starter but it was cracked, so I replaced it. The next starter that I put in started up the fridge, but than after the first cycle, just clicking and hot compressor. I opened the starter up, rotated the disk, and reinstalled. Same thing - one cycle then clicking and hot compressor. I thought maybe the overload was bad so replaced that, didn't do anything with the starter, installed all and nothing. Took the starter apart again, rotated the disk, got one cycle then clicks and hot compressor.
Ram josyula
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I had the same issue - click, no start, hot compressor. Chad inkers blog had a step by step guide that fixed the problem in 3 minutes! Search for "chad munkers magic chef fridge relay" you will not be disappointed!
Posted on May 02, 2016
John Tripp
  • Magic Chef Master
  • 4,656 Answers
I believe the start relay and the overload has failed inside the compressor wire cover. Now if you need the parts let me know. I also would like to check the compressor windings to make sure they are OK . Sea Breeze
Posted on Aug 27, 2009
Door open all night, compressor hot
replace the ptc overload/relay on the compressor this will fix your problem
May 27, 2012 | Magic Chef MCBR360S Stainless Steel...
So my mini fridge seems to have stopped working it does run i can hear ir and the compressor is gitting fairly hot i have unplugged it over night and replugged it back in this morning and still seems to...
I apologize for being 1 month late in answering your question. I just answered a different post and your question appeared after answering the other post. Having said that here goes.
If the compressor is running reach down and touch the tubing that goes into the compressor. One of them should be very hot and the other one should be much cooler about 2 inches from the compressor. If neither one of the tubes is hot the coolant system it out of coolant probably due to a system leak. (i.e someone poked the coils defrosting the unit or.. there was soldering joint that had a slow leak and allowed the coolant to escape. Make sure to listen for the compressor running continuously vs running every 4 - 6 minutes (thermal overload cycling) If the drier is clogged where the capillary (small tube) connects to it there will be one hot tube at the compressor but no coolant flow.
Thanks for choosing FixYa,
Kelly
Feb 28, 2011 | Magic Chef MCBR360S Stainless Steel...
I have a Magic Chef compact fridge. There was a lot of ice build up in the freezer compartment. I attempted to defrost it last night, but I also tried to break away the ice before it was completely...
either the defrost heater element or defrost thermostat is open behind the rear wall where all the ice buildup was and is bad or the defrost timer in the front area isn't working to defrost the unit on a 12 hour schedule,you will need to test each component
Oct 14, 2010 | Refrigerators
Fridge won't start, tries to but clicks off after a few seconds
compressor is broken if you are under warranty you can get it replaced. if not you should buy another one cause compressors are expensive to replace. costs about the price of a new refrigerator. you can try getting a used one from classifieds or craigslist.com
Aug 26, 2009 | Magic Chef MCBR440 Compact Refrigerator
My mini fridge will not work. compressor is hot.
Believe you need to change the start relay and overload, Sea Breeze
Aug 23, 2009 | Magic Chef MCBR440 Compact Refrigerator
MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
Jun 29, 2009 | Magic Chef MCWC16MCG Wine Cooler
My mini fridge will not work. compressor is hot. thanks
The first thing that I would look for is a defective start relay and start capacitor. If you are ready let me know and have a ohm meter and we can do some test. Sea Breeze.
Jun 26, 2009 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef Mini-Fridge not Working, Model # MCBR360S
Unplug and look for the thermostat control. Try jumping the thermostat wires together. If it runs then replace the thermostat. Also feel the compressor to see if running, they run very silently. Thanks, Sea Breeze
Apr 27, 2009 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef MCBR440 Compact Refrigerator Logo
6,480 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
