http://support.dell.com/support/edocs/systems/opgx260/en/sm/index.htmComputer Cover
Depending on what model you have, you may have 1 PCI expansion slot, or up to 4 PCI expansion slots.
Small Form Factor computer (SFF) = 1 PCI slot
Small Desktop computer = 2 PCI slots
Small Mini-Tower computer = 4 PCI slots
http://support.dell.com/support/edocs/systems/opgx260/en/ug/specs.htmYou need an open available PCI slot, and may not have one with the Small Form Factor computer, or Small Desktop computer.
2) The Sound Card needs to be a Low Profile one.
Maximum size depends on what model it is.
3) Computer on, and Windows running, install the sound card's Installation Disk (CD) in the optical drive of the computer, and load the software.
After the drivers, and if you also chose the effects manager, are installed; close all windows, and go back to your desktop screen.
Turn your computer off normally.
{Your computer will not use the sound card drivers, until the Sound Card is physically installed }
4) FOLLOW Anti-Static Precautions, with your Unplugged from power computer, and open the computer case.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE working on your computer.
Computer on a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
http://support.dell.com/support/edocs/systems/opgx260/en/sm/cover.htm#10993935) Physically install the Sound Card.
Find an open PCI slot, and remove the expansion slot cover from the metal frame of the computer case, that matches up to this PCI slot.
(Note the PCI slot will not be directly in line, with the expansion slot cover. It is 'one over' )
http://support.dell.com/support/edocs/systems/opgx260/en/sm/cards.htm#11047686) Attach your audio cables to the Sound Card. Plug the computer into power. WAIT 1 minute, turn the computer on.
Go to the system task bar at the bottom of the desktop screen, and click on the Volume icon. (Looks like a speaker)
Set the Volume where you wish.
(Also you may want to Right-click on the Volume icon, and make sure your audio { Sound }, is Enabled )
If you do not have the Installation Disk with the needed software on it, go to the Sound Card's support website, and download the software.
Post the manufacturer name of the Sound Card, and it's model number, and I'll guide you with the above.
For additional questions post in a Comment.
Regards,
joecoolvette
There are no visible or evident obstructions. In fact, when I put my old video card back in (even without its drivers) the computer functions just fine.
