Question about BenQ Joybee 130 MP3 Player
Can't play music and charge battery.
My mp3 player doesn't work well.
When I turn on this player, I can see benq logo but I can't see next screen. It remains that state forever and I can't charge battery too.
And it is not recognized by computer when i connect it to my computer.
Please help me. Please tell me how can i fix this problem?
Posted by intelmac701 on
5 Related Answers
Anonymous
SOURCE: My mp3 player is frozen.
on the q music thing go to help and it gives a list it might work
Posted on Feb 19, 2007
Anonymous
  • 6 Answers
SOURCE: BenQ Joybee 130 Won't play MP3
To clear this problem, you must use the "firmware upgrader" from the manufacturer. Select the "format data area" checkbox when running the utility. You can download the utility and the instructions here: http://www.benq.co.uk/support/downloads/downloads.cfm?product=722
Posted on Jun 28, 2007
Anonymous
SOURCE: WONT CHARGE N CANT TURN ON WHEN NOT CONNECTED TO THE USB'S COMPUTER
have u tried turning it on then pulling it off
Posted on Nov 29, 2007
Anonymous
SOURCE: computer wont recognize my mp3 player
try doin notin about it
Posted on Jan 08, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: MP3
Use Windows Media Player to transfer songs - make sure the lock/hold is not engaged
Posted on Jul 05, 2008
My mp3 isn't turning on even thought it is fully charged but plays music when plugged into USB
There is a Problem with the Mp3 Battery its not Charging get it Replaced!
2answers
I listen to the music for 1 hour. I turn the lock switch off. The next day the Go gear MP3 has completely discharged. I re charge it on the pc. The screen reads 'Fully charged'. The same thing...
There are two things possible.
1) You have defective re chargeable batteries in your GoGear.
2) There is some short circuit because of which the re chargeable cells are discharging.
Either way you should get the system changed. If you want to confirm if its the battery defect or GoGear. Charge the system fully and play music continuously. If the Go Gear plays for about 4 hours with out break---- its not the battery but the charging system.
2helpful
4answers
Rizone 32gb. Only charging to 3 bars instead of 4 and this takes hours and hours. Can't find shuffle setting and can't drag and drop music. On screen it shows as gone in but when i check player music has...
To charge your player, with the player on OFF, connect it to a computer or other charging device. Then, after everyting is connected, then turn your player to ON. (For some reason, my player doesn't charge if it is already ON while being connected to the computer or other device.) It will charge.
This is the solution that I use for the music. Connect you player to the computer. Turn it ON after being connected. Go to FILE NAVIGATIONN. Copy your music there. (not in any forler, but as a separate entry in FILE NAVIGATION) Next, disconnect your player from the computer. (Use the SAFELY REMOVE HARDWARE feature for this.)
On the player, there is a PLAY button (NOT THE ONE MARKED "M", BUT THE ONE WITH THE RIGHT FACING ARROW WITH THE TWO BARS) next to the volumn button. After going into the FILE NAVIGATION menue, scroll down to the song(s) and/or music you want to move. Click the song using PLAY. You will see three options: MOVE, COPY, and DELETE. Scroll down to the MOVE option. In the main menue of FILE NAVIGATION, scroll down to MUSIC. Now click the "M" button (the one next to the button with two arrows and one bar). A screen will come up that says that the file is being moved. The song will now be in the MUSIC folder.
You could use the COPY or DELETE features for their respected funtions if you want to when these functions appear.
This is as complete as I can make it.
Sony Walkman NWZ-S618F MP3 Player - Screen display not working
I Have the same problem, but mine has vertical lines running on the display, try contacting sony support
3answers
Hello!!
you likely have a music file other than an mp3 on there ( possibly wma or m4a file) i had a bunch of wmas on mine and wouldnt play, deleted them and added mp3 files and mine worked fine.
2answers
I have Sanso m250 2.0gb mobel. Logo screen is appearing when i power on after that i am unable to play the mp3 songs or play FM Radio etc..
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second.
  2. Plug the Sansa into a computer4.gif, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC4.gif Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. I do not know if this will work on other Sansa m200 type .mp3 players. You can start over with your playlists. This has worked for me.
MP3 player something wrong
Hi Samusv2,
Try removing the battery completely for about 1 minute, then put it back in then try to see if doe shte same thing. Insert another comment on this post and I will respond.  Cross your fingers.
My rio nitrus will not show anything on the screen
Ok. You have reset your device, there is a reset hole next to the DC-in hole. Then if it still not working then you have to ask for a new lcd screen/ lcd screen module. That means the LCD of your MP3 Player isn't working anymore. Good Luck
1helpful
2answers
Zen Micro
Sounds like it may be the index in your Music Library. Try going into Recovery Mode; remove battery, hold power switch to ON, replace battery, release power switch when the Recovery Mode screen appears on the screen. Run Option 1 CleanUP, after it completes run Option 4 Restart. You will get a Rebuilding Library screen when it reboots, that's normal, then it should go back to your startup screen. Good luck and let us know what happened
BenQ Joybee 130 MP3 Player Logo
Top BenQ Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a BenQ Audio Player and Recorder Expert? Answer questions, earn points and help others
