SOURCE: phaser 8560 blurr
There is an encoder on teh drum motor that picks up lubricant from the maintenance kit and causes those blurs. It eneeds cleaned or replaced
SOURCE: Xerox Phaser 8560n 07,009,42:0 error.
Hi oconde:
This is your problem.
7,009.42: The printhead is tilted back but not properly restrained in the park arms.
This will require a certified Xerox technician to repair.
Hope this helps
SOURCE: xerox error code 09,038.46:350??
Hi. The error code you are referencing is referring to Black Ink Stick Count Failure.
If the fault code is still displayed you will need to contact support to schedule a service call.
Please check out the online support at www.xerox.com\support
SOURCE: Please can you advise why the screen goes blank on
Usually this problem means that the control panel is not fuctioning properly. You have to switch the control panel and that will fix your problem. First you can try to call Xerox at 1-800 635 8100 and if your lucky they will replace it with a new one for FREE.
SOURCE: Phaser 8560N prints multiple pages when powered on
This was due to the TFTP (PXE) setting on the printer set to on. No more wasted paper at startup/wakeup after changing setting to off.
Check for obstructions in the Wiper Assembly path.
Is the Wiper Assembly obstructed by the Printhead or wiring?
