When i put the sim card in i can see all my contacts but when i try to call out i get emergency call only i have signal does this mine the phone is not unlocked?
No it doesn't mean that is not unlocked. It only means that you have a Sim card that uses a frequency that most probably your i68+ don't have. Some of those phone are sold as quadband, but are truly triband. If you phone company uses 850mhz. and your phone is a triband then you won't be able to use your sim card with the phone. Also make sure that both sim card slots are enable, go to the sim card profile and tap it, here you will have 4 options, tap on dual sim. To enable all bands you will have to go to engineer mode and that is a risky move if you don't know what you are doing.
Engineer mode: *#3646633# then go to Network set up, choose band select, and make sure that auto is checked. Stay away from HIGH SPEED SIM, if you tap it you will brick your phone and it will be useless.
