Change oil in John Deere RX75 riding lawn mower
Look at the side of the engine down low. There should be a pipe plug screwed in that has a square head. Put a drain pan under the area and remove this plug and the oil will drain out. It's best if the engine is warm. You should get 1 1/2 quarts of oil out of it. Let it drain for about 5 minutes and then re-install the pipe plug. Add 1 1/2 quarts of 30W oil and then cut the grass !
Posted on Aug 27, 2009
Testimonial: "Thanks. It worked!"
