Question about Sharp Aquos LC-45GD6U 45 in. LCD HDTV
The audio on my LC-45GD6U goes in and out (mostly
The audio on my Sharp Aquos LC-45GD6U cuts in and out (mostly out) on several high definition channels received through the CableCard (provided by Comcast). Only certain channels (e.g., HBO-HD 549, Discover, ESPN News, etc.), purportedly on the same frequency range have this audio problem, while all other channels are fine. The picture is fine. The cable tech acknowledged a problem at the node down the street, but said another tech installed an amp at the node. I'm still having the problem. The cable tech suggested it might be the TV. Could it be? Thanks.
Posted by cgoodison on
Anonymous
  • 59 Answers
If its fine on other channels i would not suspect the tv
Posted on Aug 26, 2009
Samsung lcd 40 in turns itself off all the time on digital 10
1. check you menu to see if you have the TV in hibernation mode if not. you have a TV that has heat build up after so many minutes. You didn't provide the model number for this unit.
Apr 24, 2010 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
New Boards Needed for Sharp LC-45GD6U
You might not be able to find aftermarket parts but you can find used boards that have been removed from broken screen LCDs.
What is the model number of your LCD or the part numbers of the boards?
Apr 03, 2009 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
I cannot change the channels on my direct TV receiver when tv is
Have you tried a factory reset on the TV.Also try unplugging the tv wait about 20 seconds and then plug it back in.Last check the trouble shooting in the tv manual
Feb 08, 2018 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Distorted sound comes and goes
i am going to give you the best solution for this problem, not even sharp techs know what the problem is, the only solution is to get the sound from a separate receiver, let me make myself clear, get the audio out put from the satellite or cable box. and connect it to a receiver with separate speakers. the problem is in the sound card and to replace it cost $260.00 + labor and you gonna have the same problem in a few months or it could last a year or 2 two days, who knows, don't waist your money trying to repair it. i have done 3 so far and that is the only solution good luck
Nov 26, 2008 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Sharp Aquos LCD intermittent display
Hi there.
The backlight inverter board is defective.
Replace it and your problem will be solved.
Oct 15, 2008 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Sep 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos Audio Intermittent
This is a problem with the ATSC channel's reception. Usually switching to another channel and back solves the problem.
Jul 28, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Trying to connect new HP Blackbird PC
try updateing the system pc 1st all latest drivers video ect windows update ok
Feb 04, 2008 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Open Questions:
Sharp Aquos LC-45GD6U 45 in. LCD HDTV Logo
Top Sharp Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
