Question about Sharp Office Equipment & Supplies
How to reset the counter for black developer on Sharp Printer MX-2640n
Posted by Kelly Wangi on
5 Related Answers
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Sharp AR-M165, maintenance led and developer replacement leds on
It's the drum thats causing the lines to happen. Youre going to have to get that replaced before you can reset the counters.
If you get light copies, then the developer should be replaced.
Posted on Sep 01, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Sharp AR 407
Try this procedure:
http://olsonbros.com/sharp/support/ar16x_devinstall.html
Posted on Nov 11, 2008
wheatlandsvc
Edwin Martens
  • 1110 Answers
SOURCE: Reset drum counter on Sharp AL-1644
This works on MOST sharp AL series copiers.
Press these keys in sequence:
Clear → Density select → Clear→ Density select
display should go blank. Then enter:
24 as if you were making 24 copies then press print
then enter 7 as if you were making 7 copies then press print
if successful you should see flashing 000
turn machine off then on again and the drum light should be gone.
Good Luck
Posted on Nov 03, 2009
Testimonial: "Fantastic! The code for the Sharp AL-1644 drum reset worked like a dream! Thank you."
SOURCE: I have a Sharp MX-C310
http://printcopy.info/?l=en&mod=docs&brand=Sharp&prefix=MX-C&gID=19364
Hi above is your service and repair manual it shows you what to do in there open or download and follow the instructions.
Below is you user manual, here too is what to do...
www.sharp.co.uk/.../MXC310-C311-C380-C381-C400_OM_Software_GB.pdf
Maintenance-Safety-Guide below
www.sharp.co.uk/.../MXC310-C311-C380-C381-C400_OM_Maintenance-Safety-Guide_GB.pdf
copy/paste above to address bar, if not live.
Posted on Apr 27, 2011
Sreelal Devadas
  • 66 Answers
SOURCE: How can I check drum and developer usage level for
You can press #*C* respectively, then press 22 start 1 start respectively then it will show you all the counteres including drum and developer for the 4 colors.Rate this and vote for this
Posted on May 17, 2011
Testimonial: "Thanks a lot, that's exactly what I was looking for. Now, another question: what does that mean that i.e. drum for yellow has "02" life?"
Sharp MX-M232D Copier call for service F2-40
Problem with your toner supply .... you're not getting enough toner mixed into your developer tank. Sometimes the cartridge will empty out without the machine giving warning, or the CRUM counter chip on the back of the cartridge wil zap out or wind down to zero. Try replacing your toner cartridge, if that doesn't clear the code your developer mix is out of balance and may need to be changed and reset.
Aug 19, 2013 | Sharp MX-M232D Multifunction Copier
Sharp mx - b200 reset counter
With 24-6 and 24-8 with the same procedure 24-7 you can reset developer counter.
Mar 01, 2013 | Office Equipment & Supplies
What does code DK indicate on an MX-2700N?
IT MEANS YOUR BLACK DRUM AND DEVELOPER NEEDS REPLACEMENT, IF NO PROPBLEMS ARE THERE IN YOUR CPY QUALITY YOU CAN RESET THIS BY PRESSING #*c* BUTTON RESPECTIVELY WITH NOT MUCH TIME DELAY IN BETWEEN THE KEYS, THEN MACHINE WILL ASK FOR MAIN CODE THEN PRESS 2 AND 4 THEN PRESS START THEN YOU CAN SEE THE DRUM AND DEVELOPER COUNTER RESET SELECT THAT BLACK DRUM AND PRESS OK THEN DELOPER ALSO LIKE THIS THIS WILL RESOLVE YOUR PROBLEM, IF ANY QUERIES FEEL FREE TO CONTACT AND VOTE AND RATE THIS AFTER GETTING YOUR PROBLEM RESOLVED.
Jun 12, 2011 | Sharp MX-2700N Color Copier
Our sharp MX-3100n printer is "offline" and shows code "VC" - how do I get it back online?
Apparently your machine is set to stop when the supply counters trigger a maintenance code. You can type # * C * and go into Sim 26-38 and bypass this.
VC means your cyan developer has reached its' rated life of 60,000 copies and needs to be changed. Your yellow and magenta developer which are usually changed at the same time as the cyan have also reached their end of life (VM, VY) and so all 3 will need to be changed (not black, your VK code will come up at 100,000).
You will need the color developer kit and the seals and filter. Sim 24 resets the counters and sim 25 resets the toner-developer mix ratio (this is MANDATORY or your new developer will be ruined, you must run the copier with a door open and only close it when you are ready to set the mix).
There's also various color calibrations after this you can get from a service manual. DO NOT run old developer through your machine, it will eventually lose its' magnetic properties and be carried through the copier sandblasting everything in its' path.
Jan 04, 2011 | Sharp MX-3501N All-In-One Printer
Instructions on how to add black developer to Sharp MX-3501N printer
Are you a tech or end user? This must really be done by a technician.
Mar 19, 2010 | Sharp MX-3501N All-In-One Printer
Sharp mx-2300N printer error maintenance required code vk
VK means black developer has reached end of life. You can safly carry on using the copier with this message displayed but over time the copy quality may slowly degrade. You will need to call a Sharp authorized dealer to replace the developer in the developer unit.
Dec 23, 2009 | Sharp MX-2300N Color Copier
Sharp AR-M160 Maintenance light and developer replacement light have come on together. Where do I get developer from?
It's not developer light.
It is drum unit light and maintenance.
You have to replace the Drum, Blade and Developer.
After changing them you have to reset the maintenance, drum,developer counter.
This procedure must be made by a copier tech.
But if you still want only the developer the code is AR-202D
Dec 12, 2009 | Sharp AR-M160 Laser Printer
Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Feb 04, 2009 | Sharp MX-2700N Color Copier
59 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
