AEG S70408KG Bottom Freezer Refrigerator Logo
Posted on Aug 26, 2009
Hello. my AEG santo fridge/freezer alarm was going off and couldn't get it to stop, so pressed all the buttons at the top. I pushed the on off button and it went in to the body of the fridge, then when trying to get it back turned the fridge off. Now I can't turn it back on again, and the button is not where it should be.
5 Related Answers
BIKER T
Terence Fourie
  • 909 Answers
  • Posted on Sep 20, 2007
SOURCE: AEG Santo 3778-8 KA Temperature Problem
hi tracy, think its possibly better getting a repair guy in as this fault is not streight forward. possibly a fault in the defrost circuit, or freezer fan not functioning, or possibly a leak in the system. all theese areas need testing equiptment.
Anonymous
  • 3 Answers
  • Posted on Jan 20, 2008
SOURCE: AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
Anonymous
  • Posted on Aug 11, 2008
SOURCE: AEG Santo Fridge light flashing
Here is fix photos:
http://www.elisanet.fi/mtj/santo/AEG-Santo-fix.html
electrodynam
Gordon Meredith
  • 35 Answers
  • Posted on Mar 16, 2009
SOURCE: AEG Santo fridge not cooling but freezer is working.
The compressor is obviously still good or the freezer wouldn't work.I'm sure you checked the settings,but turn the freezer all the way up (hot)after it is cool so the unit doesn't come on for the freezer,then turn the refrigerator controls all the way down to the coolest setting.listen for the compressor to start,and/or the fans to run.If the compressor starts,and no fan there may be a problem with the fan.(this is a general test I'm not familiar with your specific unit which may not have a fan,but most newer units do).If the compressor doesn't start after a short time the thermostat/control for the refrigerator section is broken,and needs replaced.
Anonymous
  • 43501 Answers
  • Posted on May 27, 2010
SOURCE: fridge freezer not keeping temp
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
The top section of my refridgerator is not cooling at all and the alarm goes off constantly even though the door is cloased what can be the problem
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
My AEG Santo 75438KG Fridge Freezer has stopped cooling, freezer is working fine but as the fridge has stopped cooling the alarm keeps going off, I tried to arrange for a local fridge repair man to call...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
My freezer is working well, however the top refrigerator has stopped cooling, what should I check begore calling a repair man?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
1helpful
AEG SANTO No_frost refrigerator beeps with 5 sec freqency
We have the same fridge, and I could not find my model either!
The label is hidden on the bottom of the top part on the left side, you need to take the veggie tray out to see it. I spent about 3 hours finding the model on the net, and in the manual it said where to look lol.
This mysterious model is the AEG SANTOS 3895-6 KG AKA S3895-6 KG productnumber 928405123-- last two digits can be 00-33.
We had the same problem, solution: press and hold the ON button for minimum of 3 seconds. The fridge switches off. Wait 10 seconds and repress the same button. That´s the quick fix.
To make it go away completely switch off fridge, pull out plug, and thoroughly clean the air vents on the back below using compressed air. After this the problem went away permanently.
Good practice to airclean every 6 or 7 months. You can find the manual for the S3895-6 KG on http://www.electrolux-ui.com:8080
5helpful
2answers
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
4helpful
AEG SANTO 3790-6 KG
hi i have got a fridgefreezer and it keeps beeping and also inside my fridge is warm but my freezer is ok what could this be
4answers
What does the flashing (warning?) light mean
Did you ever get any advice for this problem? Please repost if not.
Top AEG Refrigerators Experts
kelly
kelly
David Spradling
David Spradling
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
