Question about Coffee Makers & Espresso Machines
Had a back flow test water will not come out of any heads the water is turned on tried to Manuel turn on the water turning knob 1/4 turn still no water the unit I have is a Hunter SRC Plus
Posted by Michael Farwell on
Gary F
    Sergeant:
  • 236 Answers
Have you tried decalcifying it? Sounds like it's been too long and you have a mineral clog.
Posted on Aug 06, 2019
5 Related Answers
Anonymous
SOURCE: Garmin 525s will not turn on
I tried to reset it but it did not work. I have shipped the GPS back for a replace.
Thanks for trying to help. When I get the new GPS I will start with updating the software as described.
Posted on Oct 29, 2007
Bill Johnson
  • 306 Answers
SOURCE: Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Posted on Jul 26, 2009
co7196
Ned C Cook
  • 3433 Answers
SOURCE: shower head dripping cant turn shower knob off
Mixer valve needs repair. special tools required.
Posted on Aug 22, 2009
Anonymous
SOURCE: I have a Hunter Carefree Humidifier Plus. When I
We were having the same problem. Here is how I fixed it but its hard to explain...
I took the main white part off and laid it side ways on a table looking inside there is a tube that goes from the top towards the main fan then connects to a plastic part that is shaped like a "p" In the middle part of the "p" you an see I tiny little gear. I manually turned the gear with a paper clip a few times and it worked. I had no idea what I was doing but I was determined!!!
Posted on Jan 20, 2010
Anonymous
  • 81 Answers
SOURCE: The water comes out of both the shower head and
I will have to assume this issue developed and was not present at first use after the initial installation.
There are generally only two reasons for your problem. The first is that the diverter mechanism is simply wearing out and/or broken. The second it that there is a foreign object preventing it from doing its job correctly. Either way the diverter must come out. I have provided a couple of links below that should help get it out.
Once out, put a wadded up towel over the end of the tub spout opening so as to prevent any water from coming out of it. Then, for just a moment, turn your shower on full and adjust your temperature from full cold to full hot. This process should dislodge any foreign matter and send it out the opening the diverter came out of and also will probably get you wet. I usually plug the tub so I can catch what, if anything, comes out. Having a second person holding a bowl over the diverter opening helps reduce the water splash.
Rinse off the diverter and reinstall it. Turn the shower on and see if there is any difference in how much water comes out the spout while in the shower mode. If nothing has changed then the next step is to replace the diverter.
The diverter assembly part number is A603819
http://www.danze.com/products/pdfs/D113000_ip.pdf
http://www.danze.com/products/pdfs/D500058T_ip.pdf
Posted on Jun 02, 2010
Electronic ignition hot water heater (6gal) lights but wont get water hot. The red light inside my RV goes off and back on after about 3 minutes. When I checked the unit outside, the pilot is lt, but not...
check to see if setiment has settled on the pilot....blow it out with air if it has. This issue comes up often with water heaters and rv refers. If that is not the problem and the pilot remains lit, but never increases when the thermostat is turned up, you probably need a new gas valve/thermostat.
Feb 26, 2014 | Jayco RVs
2002 pontiac aztect overheating has new thermostat and water pump
Try removing the thermostat and reverse flushing the motor, Actually try flushing in both directions, this will tell you if you have a circulation problem but 1 thing you should know is that the water goes in the water pump and out the thermostat, try running it without the thermostat and check your water flow
Jan 13, 2014 | 2002 Pontiac Aztek
Search Fixya...
    • Test the dripping water with your hand to make sure that it is the hot water side that is leaking. Lay a rag over the sink drain to keep parts from falling down it. Locate the hot and cold shutoff valves under the sink and turn the knobs clockwise by hand until they close. If the knobs remain stiff, use a pair of pliers to gently turn them until the knob begins to move, then finish turning by hand.
    • 2
      Pry the decorative cap off the faucet top with a small thin, flat-head screwdriver. Remove the cap that has the "H" letter on it. Depending upon the handle screw configuration, use a flat-head or Phillips-head screwdriver to remove the handle screw. Gently pry up on the handle from all angles and pull it up and off the splines of the stem.
    • 3
      Use a crescent wrench to turn the hot water stem nut counterclockwise until it comes completely off the stem shaft. Wiggle the stem with your fingers and pull it out of the faucet. If the washer on the bottom of the stem is deformed, it indicates the source of the leak. However, remove the old seat from the faucet base with an Allen wrench or a seat removal tool.
    • 4
      Wipe out the inside of the seat housing with a rag. Replace the seat with the new one included in the repair package, using an Allen wrench or seat removal tool.
    • 5
      Place the new hot water stem shaft into the valve seat, and start the stem nut in by hand, turning it clockwise. Finish tightening the stem nut with the crescent wrench, but only to a moderate firmness -- do not over-tighten it. Place the handle back over the stem shaft and tap it down until it seats firmly. Replace the handle screw and tighten it with a screwdriver.
    • 6
      Turn the hot and cold water supply knobs counterclockwise until they are fully open. Turn the hot water faucet knob to the "On" position and check for leaks.
Jul 09, 2013 | Computers & Internet
All hooked up dobble cked but water only trickles so ample supply
Make sure the hot water is turned back on. Pressure balancing valves won't work if both cold and hot water is not on. Pull shower head off and test to see how it flows out of the shower arm. If good, clear out shower head. Whenever water is turned off for a time, and then turned back on, restricting shower heads and aerators usually get clogged. In the future, always open up a tub spout before turning water back on. This releases the air and other debris most effectively before testing other fixtures in the house.
Apr 23, 2011 | Moen 3175 Legend One Handle Shower Faucet...
Washer makes very loud humming noise in spin cycle but does not spin..I removed clothes thinking it was very heavy and it did spin out but when I put clothes back it returned w/no spin and loud noise..now...
Either the control board or the motor has gone bad. Here is the diagnostic mode to run to look for the errors.
The diagnostic test is performed by using the Program Knob. To START THE TEST: • On non-digital display models, turn the Program Knob to start position, Drain/Spin. • On digital display models, turn the Program Knob to start position, Touch Up. • Press Pause/Cancel to turn off LEDs. • Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate. 6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened. 7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble. 8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test). 9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating. 10. Turn the program knob (9) clicks from the start position. The control will signal the last error code.
Repost the error codes here.
Feb 12, 2011 | Frigidaire Affinity ATF7000E Front Load...
Hi, We have just bought a DeLonghi Caffe Treviso. We are not able to get any coffee/liquid to drip out of the filter holder. The problem seems to occur when we are trying to preheat the machine, for...
Sounds like you need to prime the water pump. Remove the filter holder, open the steam knob and then press the coffee delivery switch. Wait for water to flow consistently from the steamer and then close the steam knob. Water should then be forced to flow through the goup head (coffee head). If you cannot get water to flow from steamer then the pump may have already been damaged or it may have been faulty from the start. If water will flow through steamer but not for the coffee, then the group head is blocked. Good luck hope this helps and remember that all machines should be primed like this before use.
Dec 15, 2010 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Cleaning mr coffee ecm3 how
Deliming
SUGGESTED CLEANING SCHEDULE
Type of Water Cleaning Frequency
Soft water every 80 brew cycles, Hard water every 40 brew cycles
Your espresso maker may be delimed using one quart of white household vinegar. Clean the water tank first, following steps l-5:
1. Make sure the steam control knob is in the center off position and that the plug is disconnected from the electrical outlet.
2. If the machine is cool and the pressure has been released, remove the pressure cap and pour 10 ounces of undiluted white household vinegar into the water tank.
3. Screw on the pressure cap and allow machine to sit overnight with the vinegar solution in the water tank.
4. Remove pressure cap and discard vinegar through the top opening of the espresso maker.
5. Rinse the water tank thoroughly with tap water, repeating this step twice.
To wash internal parts:
Make sure you clean the inside of the water tank first. Remove the pressure cap and pour 10 ounces of fresh white household vinegar into the water tank. Screw the pressure cap back on top of the water tank. Make sure the cap is on tight. Insert the filter holder into the brew head and place the glass decanter with lid on the drip tray. Plug the machine into the electrical outlet and turn the power switch on. An indicator light on the power switch will tell you the machine is on. Place a cup with cold water under the steam nozzle. When vinegar begins to flow into the decanter, insert the nozzle into the water and open the steam nozzle slowly by turning the steam control knob downward. After a few seconds, close the steam nozzle by turning the knob back up to center. This will clean any residue left in the nozzle from frothing milk. When all the vinegar has been pumped into the decanter and the flow has stopped, turn the power switch to the center off position and allow the machine to cool. Repeat steps 1-7 twice using only tap water to rinse any remaining traces of vinegar out of the machine.
Decanter cleaning
1. Pour warm white vinegar in the decanter and let soak for 20 minutes.
2. Discard the vinegar, Wash and rinse the decanter thoroughly using a
soft cloth. Do not use harsh abrasive cleaners.
Dec 12, 2010 | Vacuums
Feb 18, 2009 | Grohe Eurosmart, 3-hole Roman Tub Filler...
Coffee Makers & Espresso Machines Logo
128 people viewed this question
Top Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Ross Keen
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
