Format the memory card. Make sure your format the card each time you finish uploading your pictures to your computer, instead of simply deleting pictures. If you can't format the card, try another card.
Well sometimes when you don't "eject" the memory card properly, the card can have registry errors which makes it corrupt and you can't view the card properly. My suggestion is to put it back in your computer and try to reformat the memory card. This can simply be done by right clicking the card in ""my computer" and choose reform.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
It sounds like your SD card might be faulty.
It is very unfortunate since the only thing that can help this is to format the card, which will delete the information on the card.
Before formatting I would try to transfer the pictures using a card-reader or go to a shop to see if they are able to retrieve the pictures for you.
Instructions to format the SD card:
Menu
Format
Press OK
hello.. your problem is not your computer,, your problem is about uploading picture from your camera make sure your picture want you to upload is jpg files type..the uploading picture is must jpg type of files,, you able to change the file type of your picture ,,, how to change? open your picture and save again with select file type choices or the to upload using other internet connection or upload using other computer to chick if your computer is not your problem,,, thank you hope i can help you have a good day!!
All you need is some editing software, click here. If this problem is occuring after uploading to a website, try rotating the picture before uploading so the "problem" will actually correct the picture.
im trying to upload picture of me onto my computer using my phone but it wont let me because it says some think about a memary card but there is no slot 4 me 2 put my memary card in.
use a sd memory card reader-no software-plug and play-make sure you don't have 2 folders in camera storing pics in different places-check in menus for folder numbers
