Question about Kenmore Freezers
Trying to find out if this is frost free. Kenmore upright freezer model 106.8262510
Posted by Melissa Boerio on
Andrew Taylor
    Top Expert:
  • Kenmore Master
  • 33,303 Answers
Yes
Upright Freezers ' Kenmore
https://www.kenmore.com/products/refrigeration/freezers-and-ice.../upright-freezers/
Kenmore upright freezers are great for the garage, basement, or pantry. ... These freezers come with a manual or frost-free defrost system, to keep rarely used foods from expiring early. ...
Posted on Jul 24, 2019
5 Related Answers
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Posted on Oct 12, 2007
Curt Downs
  • 1779 Answers
SOURCE: door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Posted on Aug 08, 2008
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Posted on Sep 22, 2008
christian nielsen
  • 358 Answers
SOURCE: fan is squeaking all the time Kenmore frost free upright freezer
Yes you need to replace it,if dont will have bigger problems.
Posted on Apr 03, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: frost free freezer is frosting up
Your door seal is not sealing properly . Check and use a hairdryer to soften the seal and the magnetic portion should seal itself against the cabinet .
Posted on Jul 07, 2009
Is a Kenmore upright freezer model 253.23424102 frost free?
No it is not frost free. You can get the manual on the link below to read about the freezer and learn how to defrost.
http://www.managemylife.com/mmh/owner_manuals/134/KENMORE-Upright-Freezer-L0307021?brand_name_search=253.23424102+
Good Luck and please rate 4 thumbs up for the free answer.
Jul 26, 2010 | Kenmore Freezers
Where is the drain tube for the water being taken out of the freezer? If it's clogged, can I clean it?Kenmore upright frost-free freezer.
behind the panel below the evaperator, use some flexible curtain wire or electrical wire to clean the tube out. Hope this helps :)
Jun 24, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer has frost in back- frig not coolling
You have a defrost parts issue.
Unplug the fridge. Remove the back freezer panel and check the defrost heater and defrost thermostat.
Without a model number I can not tell you where the defrost timer is.
Mar 04, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Door gasket for Kenmore upright freezer model 2539239712
Aug 08, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Oct 12, 2007 | Maytag Freezer MQU2057
Freezers Logo
185 people viewed this question
Top Kenmore Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
