Everex StepNote NC1502 Notebook Logo
Posted on Aug 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I dont know how to turn my wi-fi on and therefore i cant get it to connect to my dsl modem becuase the wi-fi is not on to pick up the signal
Lee Hodgson
Level 3:
  • Everex Master 4,810 Answers
  • Posted on Aug 26, 2009
Lee Hodgson
Everex Master
Level 3:
Answers
4810
Questions
Helped
1782838
Points
15941
On your Everex laptop look at your keyboard and press the following>>>>
FN + F2 they both have blue symbols on them.
Your wireless radio should now turn on and detect your wireless network.
Regards.
Anonymous
Level 1:
  • Contributor 32 Answers
Anonymous
Contributor
Level 1:
Answers
32
Questions
Helped
7557
Points
89
On your keyboard you will see an (FN) button that enables your wifi adapter if it doesent try enable it from windows (control panel)
2answers
When I connect it to bt wifi, it says the signal is strong.
Connecting to a Wi-Fi network does not means you will get an Internet connection. That all depends how the Wi-Fi router is attached to the true network by Ethernet, DSL (phoneline), or cable modem.You must contact the network owner or administrator to confim why you cannot get an Internet connection even if the Wi-Fi connection is strong.
1helpful
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
1helpful
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
1helpful
Cannot receive phone calls on a dsl setup
There must be DSL Spliter inbetween telephone line & Wi-fi modem. Please check whether you have connected telephone instrument line with that Spliter or not. According to me, Telephone instrument should connect to telephone line option on DSL Splitter to use same telephone line as internet as well Telephone.
My msi mini note pad will can up to the internet when plugged directley in to the modem but not via wireless router, how do i enable the the laptop to pick up the wireless signal
First make sure wi fi switch on laptop is turned on.
MAke sure wi fi network adapter driver installed and enable.
Right click on my network places so you can see your wi fi network adapter there if it is installed .
Right click on it then enable.
Then again right click on it then click on view for available wi fi networks.
Then it find network if any wi fi router is in range.
Then click on connect.
Let me know if you need further assistance.
Thanks.
2answers
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Just bought the apple ibook g3 clamshell
If you can detect wireless connections in your area, then you have a wireless card in your Apple.
You cannot connect to the Internet unless you have a DSL or cable modem that connects to an Internet Service Provider.
You can connect to the Internet using a public access WiFi hot spot, these are located at McDonalds, Star Bucks and at the airport etc. and some Internet Cafe. There maybe some charges for these Internet connection.
1helpful
2answers
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Wireless router
well..the wireless will pick up any signal..if you want one inside your place, you'll need a signal converter(wireless router) and a cable or dsl(phone com) internet service providor.
Top Everex Computers & Internet Experts
k24674
Jose Ramirez
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
