Question about Fujitsu Televison & Video
Fujitsu HALCYON ASU24CL1 Wall Mounted AC the unit works but Op lamp red. The Timer lamp no color. Below Timer lamp says Real Quiet and that is red. Should the Op Lamp and Real Quiet lamp be green?
5 Related Answers
TONY BIGNELL
  • 147 Answers
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Posted on Apr 15, 2009
ladywinn
ladywinn
  • 5138 Answers
SOURCE: mitsubishi wd62525 replaced lamp still no picture
If Fans are OK and color wheel is running then it is the Ballast Board Call Encompass Electronics or visit website 1-800-638-3328 they will have part number and price I found Ballast board for my DLP for only $65.00 on E-Bay Depends on who has what for sale.
Posted on Oct 05, 2009
Sheikhtijani
Shehu Pro
  • 1284 Answers
SOURCE: We have a Fujitsu Halcyon
Hi, first of all, you can get a replacement filter by contacting Fujitsu on (973) 575-0381, (866) 952-8324 toll free and you will be told the nearest Place around you where you can get it from.
Secondly, your AC not cooling might be as a result of a clogged filter, which is not pulling good air flow. If that is not the problem, it could be that the refrigerant is low, coils could be dirty, or a thermostat problem.
But i think the red light signifies that you need a new filter..
Take care
Posted on Apr 30, 2010
hvac1960
R Subramaniyam Iyer
  • 2133 Answers
SOURCE: We have a fujitsu inverter
E3 Outdoor activation of high pressure switch.
Check condenser coil. If blocked, clean it. If out door fan rpm less replace capacitor. Helpful?
Posted on Jan 02, 2011
Anonymous
  • 2047 Answers
SOURCE: Have a Halcyon ASU12CQ Indoor
Abnormal behaviour such as these are often signs of looming problems to come. If the behaviour is not regular with the unit it is best to contact service now before the problem gets out of hand. Although most times the unit might just need cleaning but you cant be too sure. Contact service to come and have a look at your unit.
Posted on Mar 14, 2011
The green operation light keeps blinking. I've reset unit and it still blinks
Could u explain more about this error,how many led light,flashing ??? Brand???model???
There is a light that is allways blinking on pump and the pump does not work
Hi my friend,
1.check inside that can open the louvers down after 3 to 5mins starting outside
2.check the outside unit its working for a moment if it try to working check the sensors
Fujitsu aou30clx compressor location detection error
You must turn off of the power for 10 minutes. Then open the front of the indoor unit and push the emergency button for 10 seconds. The compressor will unlocked.
AC unit
You should post this question in the air conditioner section so the proper experts will see it.
2helpful
2answers
We have a Fujitsu Halcyon wall mounted ductless unit (indoor Unit ASU15RLQ). It was installed in December 2007 and we've done regular cleaning of the washable filters etc. Now it is not cooling. There is...
Take care
3helpful
How to use thermostat for heat on Fujitsu IAQ halcyon
This unit comes with a remote control (optional wall mounted wired thermostat available) as a standard feature. This unit is precharged with the environment friendly R-410a refrigerant. No additional refrigerant is needed if the line set is 49 feet in lenght or shorter. In addition to its very high 20 SEER efficiency rating, the 15RLQ is only 31 in. long which makes it the smallest Mini-Split System in its category through out the industry.
This category of equipment is ideal for smaller spaces where spot cooling is required. Several models in this category are ENERGY STAR Certified, meaning they save you money on your utility bill. Residential applications including sunrooms and additions are made easier with these air conditioners and heat pumps. Do you have a warm spot in your home? Fujitsu mini-splits can provide extra cooling capacity for those hard to cool areas. Commercially, their small size makes them ideal for small offices, providing individual temperature control.
Fujitsu's I.A.Q. Systems provide residential and commercial property owners an innovative solution for clean, temperature-controlled indoor air. The Halcyon IAQ systems deliver powerful heating and cooling, are designed for ease of use and maintenance, and feature an unobtrusive design which can be integrated easily into any decor. The Halcyon IAQ systems filter dust, pollen and odor making them the perfect addition to any home!
  • Wireless Remote Control
  • Plasma Filter
  • Sleep Timer
  • 24 Hour Timer
  • Dry Mode
  • Auto Louver: Up/Down
  • Auto Mode
  • Quiet Mode
  • Auto Restart/Rest
  • Auto Changeover
  • Low Ambient
  • Cold Prevention
Warranty All Fujitsu ductless mini-split air conditioners and heat pumps come with a 2 year parts and 6 year compressor warranty.
Important: All installations must be performed or supervised by a certified HVAC technician in order for the warranty to be valid.
Televison & Video Logo
Top Fujitsu Televison & Video Experts
Joaquim Martins
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
