Air Tools & Compressors Logo
Posted on Aug 26, 2009
I wish to rewire a single phase electric motor with compositor's that is currently setup for 230 VAC to 115 VAC. The motor is a Ingersoll-Rand Air Compressor motor with the following nomenclacher. Single phase RPM: 3450 Volts: 115/230 Amp.: 15/7.5 60 hz PN: 97264097 SN: BH87
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 29, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
Helped
1746
Points
12
The motor itself should have a sticker which describes the wiring for 115. It is a small change involving a single wire moving from one pole to another inside the motor starter cap (the bump on the motor itself).
2helpful
2answers
I have a Ingersoll Rand Compressor model# 2545E10V 10 HP,3 phase and I would like to convert it to a signle phase. would this motor here be good to go with and what other items will be needed to complete...
It might. Mounting holes match? Shaft diameter and adapter match? Power supply sufficient for 5HP motor? It's a big motor! You might get a better answer from the ebay supplier.
SINGLE PHASE WIRING DIGRAM
You need a single phase motor to do that. A 3 phase motor cannot be made to run on one phase.
Sometimes IR 30 goes into a strained free wheeling state
Did you change the 3 phase motor out with a single phase motor? A 3 phase motor cannot be made to run on single phase.
I have an ingersol rand 2420n5 t30 and i want to convert it from single phase to 3 phase any help thanks
Hi robles212
To convert your T-30 to single phase you will have to do one of two things.
1. Change the motor to a single phase motor
2. Buy and install a "Phase Converter" to convert 3 phase to single phase
Please rate me
Bud
Ingersol rand single phase t-30 compressor with twin cyl slow/ dragging
Quincy QT-5, with an 80 gallon tank. I was very patient and found this on CL. If you are flush with cash, do as you wish. If you are looking for the best bang for the buck, CL will produce!
X2 on the CL find....
Picked up a basically new Ingersoll Rand, T30 220v/2 stage for $500
Increase Engine Horse Power.
Trying to rewire my ingersoll rand air compressor motor, psi switch motor starter, need some kind of diagram, it has a 5hp single phase 220
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
1helpful
Hi,I got a Ingersoll Rand type 30 model 234 compressor.It looks good but it has no motor.I'm thinking like 120v,3horses?,but not sure about rpm.any help would be nice.thanks
According to the information you provided your looking at a 10 HP motor at three phase. Do you have three phase at your location? If not I would look into getting a single phase compressor. If you do want to get it going I would notify your local IR dealer so they can get you the right Model number, RPM, Pulley and Motor Frame Size to match your unit.
Please read below....Jim...if this helped you please send me a positive response...Thanks!
Ingersoll-Rand Type-30 Electric-Driven Two Stage Horizontal Air Compressor - 120 Gallon - Fully Packaged IR 2545E10VFP
  • Designed for heavy shop or industrial use, Ingersoll-Rand Two-Stage electric air compressors provide the quality and performance that are ideal for most applications and users, including: automotive service and body shops; fleet maintenance; machine shops; production and manufacturing lines; construction; wood working shops; dry cleaners; car washes; maintenance/repair shops and farms.
  • Durable cast-iron, two-stage design offers extended pump life for years of trouble-free service 175 PSI maximum operating pressure
  • 100% continuous duty for tough applications
  • Automatic start/stop control/pressure switch operation
  • Includes motor starter, oil sight glass (10-15 HP only), manual drain and ASME tank
  • 10HP, 3 Phase 200, 230 or 460 Volts
  • 120 gal, horizontal tank
  • 35 ACFM @ 175 PSI
I am changing from 460 V to 230 V on a Ingersol Rand Compressor motor # 32036006 and I cant get it to start it turns real slow is this supposed to have some sort of a motor starter capicitor set up ?
Recheck the way you have the motor leads hooked up, make sure they are correct. You did re connect the motor leads didnt you? You are not trying to run it on 230v single phase are you? Assuming it is a dual voltage motor, the leads will have to be re connected from hi voltage to lo voltage. Also when you cut the operating voltage in half the operating current(amps ) will double, all this info should be on the motor name plate. This motor does not use a capicitor to start it
Top Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
