Nikon COOLPIX S52 Digital Camera Logo
Anonymous Posted on Aug 26, 2009
Transfer of avi file from nikon S52 to adobe premier pro.
When i try to transfer a film file from the S52 to Premier pro I get a 'unsupported compression in file' message.
Anyone know how to get the Premier Pro to accept the avi file?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
274
Points
Problem solved!
Convert the avi file from Nikon S52 to .mpeg1
Premier accepts this format. The file has to be renderd before it can be used in Premier. Files can be editted in Premier.
tip
Convert/Edit Nikon D7000 MOV to WMV/MOV on Adobe Premiere Nikon D7000...
Convert/Edit Nikon D7000 MOV to WMV/MOV on Adobe Premiere <br /><br /><b>Nikon D7000</b> breathtaking Full 1080p HD Movies with Full Time Autofocus and external stereo microphone jack to record cinematic-quality movies up to 20 minutes all enhanced by NIKKOR interchangeable lens quality and versatility. <br /><br />But this MOV video format came from Nikon D7000 is a long GOP format that is highly compressed, it is not a good editing format. So you will not playback or edit smoothly the highly compressed MOV on your editing software,like: Adobe Premiere , Sony Vegas , Windows Moive Maker.etc <br />A professional video converter is essential to make Nikon D7000 files editable on Adobe Premiere Elements. And <b>Aunsoft <a href="http://www.aunsoft.com/video-converter/">Nikon D7000 MOV Converter</a></b> is the right program to convert and edit Nikon D7000 to playable and editable video formats. <br /> <br />To help Nikon D7000 owners get rid of this trouble, I will show you the easiest and quickest way to <b><a href="http://canon-videoconverter.com/2011/07/convertedit-nikon-d7000-mov-to-wmvavimpgmov-on-adobe-premierecs4/">Convert Nikon D7000 MOV files to WMV/AVI/MPG/MOV for Adobe Premiere Elements</a></b>. <br /><br />Step 1. Load H.264 MOV files into Aunsoft Video Converter. <br />Drag and drop specified MOV files from hard drive to this program or click "Add" button on the menu bar to import video recordings. Batch video files are allowed to load, joining several video files into big one can be realized by ticking the checkbox of "Merge into one file". <br /><br />Step 2.Choose Adobe Premiere MOV/WMV as output format. <br />Click "Format" option and choose <b>Adobe Premiere/Sony Vegas -&gt; MOV (AVC) (*.mov) ,WMV, MP3G-2</b> as the out put format. If you get some interlacing 1080 MOV footage, just hit button "Editor", click "Effect" and tick the checkbox of "Deinterlacing" at the bottom of editor interface. In this way, interlacing images will be removed automatically. <br /> <br />Step 3. Set video and audio parameters to get high quality of output file. <br />Click "Settings" button and you are allowed to custom several parameters. I suggest that you should set size, bitrate and frame rate exactly the same as the original video recordings. In this way, you will suffer the least loss of video quality. <br /><br />Step 4. Start the conversion from <b>Nikon D7000 MOV to MOV/WMV for Adobe Premiere Elements/CS4</b>. <br /><br />Hit the "Convert" button under the preview button and this <b><a href="http://www.aunsoft.com/video-converter/">Windows Nikon D7000 MOV Conversion</a></b> will start this conversion immediately. <br /><br />After a while the .wmv , .mpg, .mov file will be ready in the output folder. Just run Adobe Premiere and import the .wmv/.mpg file for video editing.The output videos are compatible with other editing software like Windows Movie Marker, Kdenlive, Adobe Premiere Pro, Adobe After Effects and Roxio Toast.etc. <br /><br />Tips: If you are Mac users, you can convert AVCHD/MTS/M2TS files to other editable and playable video formats, like MOV for iMovie and Final Cut Studio(Final Cut Pro, Final Cut express), MPG for Magix Movie Edit Pro, MOV for Adobe Premiere and ect, with the help of <b><a href="http://www.aunsoft.com/video-converter-mac/">Nikon D7000 MOV Converter for Mac</a></b>.
tip
Edit flip camera files with Premiere Pro
Overview of Adobe Premiere and Flip Camcorder:
Adobe Premiere Pro is one professional, real-time,timeline based video editing software application. Flip cameras store their video in a high-definition MP4 format. However, you will likely not be able to edit the video by importing it into Premiere Pro without converting it. The best solution to make Flip Slidehd/Ultra/Mino camcorder mp4 videos edit on Adobe Premiere Pro version 1.0, 1.5, 2.0, CS3, CS4 and CS5.
Best solution - Flip to Adobe Premiere Converter is a magical app for Premiere Pro fans to import and edit flip video in Premiere Pro AVI, MOV, MPEG (MPE,MPG), AIFF, MP3, WAV, WMA, etc. Flip Video to Adobe Premiere Converter easily convert flip camera videos to Premiere Pro with no quality loss. Under the help of the Converter, you can import the output video and edit it in Premiere Pro with ease, no matter which Adobe Premiere Pro version you possess. Furthermore, it can also support you to import Flip video to Windows Movie Maker/WMM.
Guide to import/edit Flip videos in Premiere Pro with several simple steps.
Part One: Convert Flip Video to Adobe Premiere Pro Format AVI, MOV, MPEG etc.
Step 1: Load files
After download and run Flip to Adobe Premiere Converter, Press "Add File" to import flip .mp4 video to the program.
Step 2: Select the output format and its destination
Select the output format in the drop-down list of "Profile", like DV-AVI. Specify its destination when click the "Browse" button.
Step 3: Click "Convert" button to start converting flip camera video to target format.
After successfully convert Flip to Premiere Pro supporting formats, you can import the video to Adobe Premiere.
Part Two: How to import output video clips and other files into Adobe Premiere Pro?
Adobe Premiere accepts you to import a single video clip, multiple clips, or an entire folder of clips. You can also import a variety of audio and still image files, including sequences of images and layered Photoshop files.
Select File > Import from the main menu.
Tip1: To import a single file: Locate and select the file, then click Open.
Tip2: To import multiple files: Hold down the Control key to select multiple files, then click Open.
Tip3: To import a folder of files: Locate and select the folder you want to import, then click Folder. A new bin is created in the Project window, containing the contents of the folder.
Tip4: You can also import files and folders by dragging them from "Finder" into the Project panel.
Notes:
1.The pixel size of your clip cannot exceed 4000 x 4000 pixels.
2.If your imported clip appears distorted or stretched, its pixel aspect ratio may be set incorrectly.
Well Done. Enjoy Flip video editing in Adobe Premiere Pro with Flip to Adobe Premiere Converter.
Related: Flip camera review: The best flip camera after Flip Ultra, Flip Mino, Flip Ultra HD and Flip Mino HD.
on Aug 11, 2010 • Computers & Internet
4helpful
How do i import a video?
dear you need to convert your file into a format that is supported by the premiere like avi or smthng else(check out documentation for the formats supported by your software).
To convert your files from one format to another you need a video converter software like Total video Converter or ImToo MPEG Encoder.
you can find tvc here
http://thepiratebay.org/torrent/4667561/Total_Video_Converter_v3.21___Patch_By_ChattChitto
http://isohunt.com/torrents.php?ihq=imtoo+mpeg+encoder&ext=&op=and
for more download links mail me at [email protected]
I have Matrox RTX100 card when i run premier error message appear
There are occasions you find yourself facing DVDs as source videos for a project or need to do some "operation" on DVD with Adobe Premiere Pro. Whether it's for a wedding video, a sport highlight film, a video game demo, or some other project, more and more people have their video footage on DVDs (only) these days. Obviously this is not a wise move for editing - the video file has already been compressed, so you've already lost quality to begin with. But the fact is that you have to work with what you've got.
There are many problems would arise when importing and editing DVD to Adobe Premiere Pro, I just listed some of them here below, just check them out, if you happen to fall into one of their situation, then just read patiently, you will find an answer at the end
read more...
http://www.dvdripperformacos.com/dvd-to-adobe-premier-pro/
tip
Edit Flip Camera File with Premiere Pro
Premiere Converteris a magical app for Premiere Pro fans to import and edit flip video in Premiere Pro AVI, MOV, MPEG
Step 1: Load files
Notes:
on Aug 10, 2010 • Computers & Internet
tip
Overview of Adobe Premiere and Flip Camcorder: Adobe Premiere Pro is one professional, real-time,timeline based video editing software application. Flip cameras store their video in a high-definition MP4 format. However, you will likely not be able to edit the video by importing it into Premiere Pro without converting it. The best solution to make Flip Slidehd/Ultra/Mino camcorder mp4 videos edit on Adobe Premiere Pro version 1.0, 1.5, 2.0, CS3, CS4 and CS5.
Best solution - Flip to Adobe Premiere Converter Flip to Adobe Premiere Converter is a magical app for Premiere Pro fans to import and edit flip video in Premiere Pro AVI, MOV, MPEG (MPE,MPG), AIFF, MP3, WAV, WMA, etc. Flip Video to Adobe Premiere Converter easily convert flip camera videos to Premiere Pro with no quality loss. Under the help of the Converter, you can import the output video and edit it in Premiere Pro with ease, no matter which Adobe Premiere Pro version you possess. Furthermore, it can also support you to import Flip video to Windows Movie Maker/WMM.
Part One: Convert Flip Video to Adobe Premiere Pro Format AVI, MOV, MPEG etc. Step 1: Load files
Part Two: How to import output video clips and other files into Adobe Premiere Pro? Adobe Premiere accepts you to import a single video clip, multiple clips, or an entire folder of clips. You can also import a variety of audio and still image files, including sequences of images and layered Photoshop files.
Why not download Flip Pro to have a try?
on Jul 20, 2010 • Cameras
Video downloaded cuts off in adobe premier elements 4
read more
1helpful
4answers
.MOD files in Adobe Premiere Pro C3
WOAH thanks changing the file names worked! That took me forever to figure out!
How to use adobe premier to edit the film?
Hi
Please visit Adobe's site. They have wonderful tutorials to help you understand and edit films and other things using Adobe Premier.
http://www.adobe.com/ap/products/tips/premiere.html
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
