Question about Hotpoint UY46 Style Line Stainless Steel Electric Double Oven
Hotpoint BU62 double oven, no grill functioning
I can't get the top oven to work as a grill.
The oven/grill selector button (second from left) says plate warm then the temperatures, no full grill or half grill.
The oven functions as an oven o.k.
The cooker is set to manual.
Posted by joandear on
Anonymous
    New Friend:
Keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Posted on Feb 07, 2010
Top oven not working in a hotpoint dh53ck
change the thermostat and check.
Nov 07, 2013 | Ovens
Function selector knob loose
contact the bosch service agent for spares
Sep 03, 2017 | Bosch Ovens
Hotpoint SD97PI oven self cleaning funtion and grill not working
The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. The most common complaint I have had with built in ovens besides the element burning out, is the oven door locked shut. When I get to the house and I ask to tell me a little bit of whats going on the story always starts " well, I was using the self clean option" or some variation of the sort.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 22, 2012 | Hotpoint Ovens
What is the power ampage for the hotpoint double oven bu62 ?
All appliances must have a rating plate attached. This gives the load etc. It hsa to be there by law, and on some appliances, is duplicated on the back. Max draw on a double oven would be 3 elements and a fan.
Dec 08, 2009 | Hotpoint UY46 Style Line Stainless Steel...
How do you set clock on hotpoint bu62 double oven
electronic clock I presume. first of all turn power off then back on. Clock display will now be flashing.
press and hold the two buttons far left and hold in. at the same time press the + or - button to set clock. You should also have a pan icon between the hours and minutes iluminated which means you are in manual mode
Oct 21, 2009 | Ovens
Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 03, 2009 | Ovens
Oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Plz rate my solution
Thanks.
Dec 26, 2008 | Ovens
Hotpoint BU62 display works but nothing else does.
If the display is flashing auto, then you need to reset it to manual, otherwise oven will not work,
The grill should still work regardless..If you have your handbook, refer to (What if something goes wrong).
If no hand book, type in HOTPOINT USER MANUALS in your browser bar, and follow the links.
Please leave feedback
Dec 02, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint double oven
Top oven works bottom oven fan works but bottom oven does not work and cannot get rid of auto signal
Jul 22, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint BU62 bouble oven
sounds like the bott oven element has gone, or faulty thermostat.
Dec 09, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint UY46 Style Line Stainless Steel Electric Double Oven Logo
900 people viewed this question
Top Hotpoint Ovens Experts
Michael Thomas
Michael Thomas
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
