Question about Radio Communications
I have a bearcat 145XL. I can turn it to weather and hear that just fine, but not hearing any calls. All codes are correct
Posted by Becky Deal on
Jim
    New Friend:
  • 28 Answers
Depending on where you live, your county may have decided to go to the new 800 mhz band. Many county police, fire, ems, and 911 centers have gone to the new digital modes and moved to the 800 mhz band. Older scanners do not work well.
Posted on Aug 29, 2019
5 Related Answers
NickBeamAA
Nicholas Burress
  • 53 Answers
SOURCE: Can't hear caller
The earpiece speaker has gone bad. Unless you have access to a replacement speaker and can solder you will have to take the phone to you nearest Motorola service center.
Posted on Sep 06, 2007
Anonymous
SOURCE: Can't hear callers, but they can hear me
The problem might be the hearing volume. As far as I know, the only way to change it is in the middle of a call.
Here's what you should try...
1) Call someone.
2) Using the silver button on the left side of the phone, press the up arrow key a few times until the volume is all the way up. It will say "Hearing Volume".
Hopefully that will solve the problem and your phone will be working fine.
Posted on May 21, 2008
Anonymous
SOURCE: how to program a uniden bearcat bc 145xl 16 channel scanning radio
I'am having a problem. I do not have codes for a uniden bearcat 145 xl 16 channel, can someone help me please?
Posted on Aug 03, 2008
Anonymous
SOURCE: Cannot hear incoming call or caller cannot hear me
cannot hear incoming calls or outgoing calls
Posted on Apr 08, 2009
Anonymous
  • 35 Answers
SOURCE: Progamming instructions for Uniden Bearcat 145xl
Try this link.
Now depending on where you live and what you are planning on listening in on there can be a couple of things that you may need to take into consideration.
First in some areas it is illegal to listen in on Police Frequencies.
And Second is that there has been a large number of areas moving their Emergency transmissions over onto Trunked Systems which I don't think your Scanner Handles.
Posted on Jan 08, 2010
I need a schematic for this scanner
This site says they have them but you have to sign up to receive the free download.
platformusers net
Oct 29, 2015 | Uniden Bearcat BC 145XL 16 Channel Scanner...
Looking for manual
Thank you for being a loyal customer; unfortunately, as we no longer manufacture this unit, we do not have the owner's manual. You can try running a google search for it or it can be purchased from Vintage Manuals: http://www.vintagemanuals.com/manuals.php?manufacturer=Bearcat¢er=
May 30, 2015 | Uniden Bearcat 16 Channel Scanning Radio...
HELP with bc350c scanner, won't pick up feeds
Sounds like an antenna problem. Remove your back-of-set antenna and see if reception changes. If it's the same or nearly the same, check the antenna solder connections inside the set and resolder if necessary. You might also try an outdoor antenna or one of the indoor/outdoor units that's enclosed in PVC pipe. These are fairly inexpensive and can be found on eBay or other sources.
Nov 28, 2009 | Uniden BC350C Base Scanner
Bearcat 140 scanner.It will scan but will not pick up any signals,even witha tower antenna? none at all and not myweather channels also.
If you are good with electronics, go to www.mods.dk. They have an alignment manual for the Bearcat 140 series that also includes troubleshooting advice and schematics.
Use the manual for the Bearcat 145XL. It is virtually the same radio as the 140.
The link to the file is:
http://www.mods.dk/downloadmanual.php?RefFil=BC-145XL_Alignment.zip&radio=
Sep 28, 2009 | Uniden BC244CLT Base Scanner
BEARCAT BC 175 XL--Where might I download manual? Thanks
hi . i w given a Uniden Bearcat 175XL 16 channel scanning radio. the OPERATION buttons are: PRI SPEED WX LIMIT SRCH HOLD DELAY LOCKOUT and in orage color: SCAN MANUAL. please help. the only thing i can get to hear is the WEATHER CHANNEL. i cant even hear the squelch. can u help
Mar 21, 2009 | Uniden BC340CRS Base Scanner
Help with programing my scanner
If you don't hear the weather the scanner is malfunctioning & needs to be repaired. If you live near NJ, call 973-831-5900 to speak to a tech familiar with Bearcat scanners.
Aug 01, 2008 | Uniden BC248CLT Base Scanner
How to program a uniden bearcat bc 145xl 16 channel scanning radio
May 31, 2008 | Health & Beauty
Programming Bearcat BC 55XLT Scanner
Ok doc, I'll see if I can walk you thru this as there don't seem to be a manual available for download.
* Push manual button and bring it around to channel #1
Enter the freq including the decimal point. Push the E button to enter the freq into the first channel.
* Push manual again and move to channel #2 and repeat.
If you need some new freq's for your area, go here, click on your state, county, and it'll give you a complete rundown.
http://www.radioreference.com/apps/db/
If you need 10 codes for your area, go here and click on your state.
http://www.nat-com.org/radio.htm
If you need anything else, let us know,, Mechanic
Feb 19, 2008 | Radio Communications
Radio Communications Logo
120 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
