Question about KitchenAid Food Mixers
KitchenAid Hobart Model KFP400 Food Processor REPLACEMENT PARTS
Need a replacement work bowl for a KFP 400.
Posted by George Foster on
5 Related Answers
doobo67
  • 49 Answers
SOURCE: need replacement bowl for KitchenAid 3-C
put a watch on Ebay for the bowl they come on there once in a while
Posted on Jan 01, 2009
Joe Hogan
  • 10865 Answers
SOURCE: replacement bowl for Hamilton Beach Scovill model #702-4
go to this site and you can order one:
http://www.smallappliance.com/department.asp?cur=USD&sid=18956&gid=18970&shopBy=Category&cam=drg_247-10377&drg=247-10377&gclid=CPPEqdb6zZgCFQw9GgodtGMO1A
Posted on Feb 08, 2009
Anonymous
SOURCE: Replacement parts for Bravetti platinum pro food processor
for replacement parts on bravetti products call 1-800-798-7398 or www.euro-pro.com
Posted on Apr 15, 2008
Joe Hogan
  • 10865 Answers
SOURCE: Need replacement blade for Russell Hobbs hand mixer
go to this page http://www.russell-hobbs.com/parts.shtml and order what you need directly from Russel Hobbs.
Please mark this answer as a fixya! thanks
Posted on Mar 18, 2009
QuietRiot
  • 145 Answers
SOURCE: my kitchenaid processor is not working
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Posted on Aug 08, 2009
KitchenAid ACCOLADE 400 Mixer.When mixing dough the bowl jumps out of the the bowl lock. How can this problem be resolved?
I know this sounds a bit simple but the bowl cup can sometimes actually wear out and a very fast (# screws) and a new one and the problem is solved. If however there is a problem on the head hold down set screw (under the mixer in the cavity ) it can come loose then the mixer head can bounce all over the place causung the bowl to get loose in the holding cup at the base of the mixer., I hope this helps, let us know if you need more, we can FixYa
Feb 22, 2015 | KitchenAid Food Mixers
Why is my hobart mixer smoking?
The windings inside the motor are heating up from either a prolonged over load from too much or too thick ingredients in the bowl or there is a short in the motor. Either way Hobart has replacement parts available.
May 19, 2014 | Hobart Food Mixers
Replacement parts for Kitchenaid mixer model K5SSWW
Use this link to find parts. Have your model number available.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD
Once you have the correct part number, you can google "KitchenAid replacement parts" and purchase from a vendor of your choosing.
May 02, 2014 | KitchenAid K5SS Heavy Duty Commercial...
Where would I find a bowl lift replacement mechanism for a kitchenaid 5 qt mixer model K5SSWW.I have a kitchenaid 5 qt mixer model K5SSWW. I need a bowl lift mechanism replacement part but can't find this...
The model number seems to be valid-but given the age of the unit few parts are readily available. You might want to try eBay or a used appliance store (or even Goodwill) to find a donor machine.
May 02, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Where can i find a hobart k45 replacement cord
You can purchase a replacement power cord from Amazon.com. It is part number 9701025 and includes the grounding style plug which the original did not have. It can also be purchased from your local Sears parts store but it will be much more expensive
Apr 26, 2012 | KitchenAid K45SS Classic Stand Mixer
Which part do i need to replace?It seems like I put too much flour.in the bowl.then the mixer started to work very slow.I havea kitchenaid mixer made by Hobart Corp. model k5ss max watts 300 hz 60...
Hello Jovana,
First thing you are going to have to do is take the planetary off and check the key and the gears in the planetary. The parts that you may need to replace are endless as we do not know what may be broke in the unit. More than likely it will be in the planetary of the unit if you get it off and do not find anything post back to this thread and I will get you started on the next step.
Thank you for choosing FixYa
Dec 15, 2010 | KitchenAid 32685 Mixer
Mine is a K5-A Hobart Kitchen Aid mixer and the back bowl pin broke off so I can't click the bowl in place any more. Please help!
sounds like you need a new bowl lift cam, on the n-50 which is a hobart table-top model pull top off pedestle, you will see the cam you have to remove one cotter pin and remove one split pin install new cam reassemble
Dec 31, 2009 | KitchenAid K5SS Heavy Duty Commercial...
I have a Hobart N50 and am in need of a SS bowl. The bowl pins are 8 7/8" apart. Do they make a replacement bowl for this? I've seen the ones that have 9" bowl pins. Thanks, Ron
can buy hobart bowls from lots of places, or use the correctly shaped kitchenaid ones, both fit.. i like the lip and thickness of the hobart bowls, bought mine from globe equip.. do u still have the service manual, if so i would be real intrested in it, please
Jun 14, 2009 | Hobart N50 Stand Mixer
Need replacement bowl for KitchenAid 3-C
Jan 01, 2009 | Food Mixers
Food Mixers Logo
263 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Colin Stickland
Colin Stickland
Lee Hodgson
Lee Hodgson
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
