Question about Traxxas Toys
Hi can you please tell me if there is a big difference between the traxxas rustler 4x4 brushed and the traxxas rustler 4x4 vxl brushless?
Posted by jarrah ham on
5 Related Answers
Matthew Atwood
  • 88 Answers
SOURCE: Just tried to run a new Rustler VXL in the snow.
If the motor is not trying to move at all check to make sure that the motor is connected to the speed control and the speed control is connected to the receiver. If you can hear the motor run, check the pinion gear on the motor to make sure it is tight, and check the slipper clutch to make sure it has not backed off.
Posted on Dec 16, 2009
rock2134
SOURCE: traxxas rustler electronics arent working when i
take the esc apart buy the four screws on the bottom if it smells like bad electronics your screwed
Posted on Aug 11, 2011
Chris Nunez
  • 19 Answers
SOURCE: my rustler traxxas rc truck
it is your motor titan 12 t it is burnt out I had the same problem just replace the motor and your golden
Posted on Sep 19, 2011
SOURCE: traxxas bandit vxl doesn't work i left my traxxas bandit vxl for 1 day and came back and drove and when i got outside and drove pass my sidewalk to go on the road the esc started flashing red slow
Are you running a lipo or nmhi? You could have the lipo cut off turned on and the battery is too low. Or it could have a bad motor. Try hooking up another motor an see what happens. Or try to turn off lipo mode.
Posted on Apr 20, 2012
jake
  • 36 Answers
SOURCE: Traxxas rustler I forgot to mark the channels for
simple process of elimination, start with the steering servo,plug it into one of the sockets and test the steering. if it does not work, move it to the next socket. not too sure why you have a 4 channel radio tho, you only need 2.
Posted on Jun 21, 2014
WHERE CAN I GET A SCHEMATICS BOOK FOR A TRAXXAS STAMPEDE VXL 4X4 WITH TSM?
Traxxas website has copies of the user manual, parts list & exploded view schematics that you can view, print and/or download. Follow the link below:
https://traxxas.com/products/models/electric/stampede-4x4-vxl-tsm?t=support
Sep 24, 2017 | Traxxas Toys
My traxxas slash 4x4 vxl keeps making a clicking noise from the transmission
there may be a piece of debris got in there. I had many issues with my traxxas car, and sold it off to someone else. losi makes much better
Oct 21, 2013 | Traxxas Slash 4x4 VXL RTR w/2.4 TQi Amsoil...
CANNOT GET GREEN LED ON 2218 TRAXXAS RECEIVER
Hi I am having problems with my 4x4 slash 1/10 scale
When I turn on the vxl-3 and that turns green but the traxxas link goes red for 3-4 sec then starts blinking red can anyone help please
Jul 07, 2012 | Traxxas Link 2.4 Ghz 5 Channel Receiver...
Traxxas bandit vxl doesn't work i left my traxxas bandit vxl for 1 day and came back and drove and when i got outside and drove pass my sidewalk to go on the road the esc started flashing red slow
Mar 13, 2012 | Traxxas Bandit Vxl Brushless Buggy
Hi my name is fabio i have got a traxxas nitro petrol . the problem is it wont start it is a pull start one and i have took the glow plug out and heated it up but steal dnt wona go any sugestions ?
So you never had it running yet? Or did you ? Can you turn the motor by turning the flywheel ? If not it is seized and you need to heat up the motor to turn the engine again. Leave it at BDC ( bottom dead center) when you turn it off.
Jan 19, 2011 | Traxxas Bandit Vxl Brushless Buggy
How can you adjust a traxxas rustler for a novice driver so it doesn't go so fast?
When turning on, press and hold the button on the ESC until it flashes 1, 2, 3 times then let go of the button. You are now in novice mode.
Dec 24, 2010 | Traxxas Stampede and Rustler Vxl
My traxxus rustler has stopped working xl-5
I have a Rustler vxl and the same thing happened to me. Have you tried re-programming the controller to the car. look in your manual and you should see that the throttle must be programed for full extension for the brake and full compression for the "give it the gas". it has to do with the speed controller on how to get it set right.
Jan 26, 2010 | Electric Traxxas Rustler Vxl Brushless Rc...
Toys Logo
140 people viewed this question
Top Traxxas Toys Experts
John mullen
gbob59
Steven Jeannides
Level 1 Expert
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
