Nokia N70 has stopped ringing. It works fine otherwise. the radio is fine and even the keypad tones are working. I formatted the phone and even installed the ring tone patch. Yet no luck. Please help
I suspect that your mobile is effected with virus that is the reason it is not detecting the memory card.
If you have formated the memory card with fat32 it will not get detected in the mobile, please reformat it with Fat only.
Else please format your phone with taking backup of your important data.
Here are the steps to format N70
Turn off your mobile.
Press and hold call button + star button + number 3 and turn on the mobile and wait until you see time settings.
The setting you are looking for is under "menu - tools - profiles - general - personalise" and you change ring volume and ring tone. When you understand this, you can also create additional profiles and switch between them for different situations.
Ok, sorry for the confusion. I'll elaborate it this way. I have a Nokia N70 all the data from memory card got deleted. When I tried to access the card, it said "Memory card corrupted". I tried to format it but it doesn't work. I even connected it to PC but PC doesn't recognise the card. Hope this is clear. Please help!!
If you set the profile ring tone to OFF. Then select a contacts' number and assign it a Ring Tone. When that contact calls you the Ring Tone you assigned will ring.
If you select the same Ring Tone for all your contacts in a group they will all sound the same when they call.
Or select the same ring tone for a profile, but cancel the Tone you assigned to the contact(s).
