Question about Panasonic Lands Phones
Hi, i purchased Panasonic KX TG4500B base unit and one hand set, 3 lines connected to the base unit, i will use only the base unit, but when there is a missed call, i can't see that which line is missed call. and same thing with the messages, i can't see that the message is for which line? only i can see caller's info and time. doesn't show which line is called when i missed the call. Thank you for your help...
Posted by ikorkmaz on
guyvstewart
    Habit-Forming:
  • 115 Answers
In the window, you should see the Name, Number of Caller, and at the bottom, it should say which line number, ie. line 1, line 2, or line 3, it will not say which number the call is on. If you need the user manual, you can find it here: http://service.us.panasonic.com/OPERMANPDF/KXTG4500B.PDF
Posted on Aug 28, 2009
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
Oct 25, 2010 | Panasonic KX-TGA101S Cordless Handset
Setting up voicemail for base unit and handsets
Download a pdf instruction manual from panasonic.com od pdf on internet ....
Jun 11, 2017 | Panasonic KX-TG4500B Phone
Let our Experts solve your "Panasonic tga101cs base will not play back messages The message is recoverable from the 3 hand sets" Problem
I've just got a 2nd system of 3 handsets (KX-TG1033, DECT 6.0). I have also the same sytem in my house. Is it possible to expand 3 new hansets (number 4,5 and 6) to my existing base unit?
Mar 23, 2009 | Panasonic KX-TG1033S Cordless Phone
No KX-TGA101S communication with KX-TG1033S
The additional handsets must be registered to the base unit. Here are the instructions from the manual:
HANDSET
1. [menu}
2. "handset settings" - OK
3. "Registration" - OK
4 "HS registration" - OK
BASE UNIT
Press and hold [LOCATOR] until the registration tone sounds.
-if all registered handsets start ringing, press {LOCATOR] to stop, then repeat this step.
-after the base unit beeps, the rest of the procedure must be completed within 1 minute and 30 seconds.
HANDSET
Press [OK], then wait until a beep sounds and Y stops flashing.
Jan 31, 2009 | Panasonic KX-TGA101S Cordless Handset
Base Unit does not work
Turns out the A/C adaptor was bad. Replaced it and all is good!!
Dec 17, 2008 | Panasonic KX-TG4500B Phone
KX-TG4500B
The only way to loose your saved numbers is to delete them or initialize the system. Removing the power, battery and hitting the reset button will not delete your settings messages or phonebook.
Go ahead and remove the battery, power and try the reset feature it just may solve your issue with this unit.
Apr 03, 2008 | Panasonic KX-TG5632 Phone
No Link To Base Unit
I am having the same problem!
Mar 10, 2008 | Panasonic KX TC1743B Cordless Phone
Lands Phones Logo
147 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
