Question about Video Cameras
How to install Pyle rear view backup camera
How to video to install backup camera
Posted by Becky Weber on
5 Related Answers
vichoo06
SOURCE: what is the passkey for a pyle 7
The passcode is 8888 I sure hope that someone has answered this before this time.
Posted on Nov 26, 2010
Anonymous
  • 233 Answers
SOURCE: i have the pyle rear
the green wire probably goes to your reverse light switch to turn the camera on like a remote wire for an audio amp.
Posted on Jan 30, 2011
Azrael SRL
  • 11800 Answers
SOURCE: As far as the Pyle
They installed it incorrectly: the unit should have been powered from the reversing lights, this way it would have been active only when the reverse is engaged. Instead they have powered it directly from the main contact so it stays permanently on.
Go back to the ones that installed it for you and ask them to do their job properly, to power it correctly.
Posted on Jun 02, 2011
Anonymous
  • 492 Answers
SOURCE: where do you hook the
The colors red and black usually indicate a constant power (red) and ground (black), which stands to reason for a camera. There should also be video connections out (possibly RCA looking wires). Hope this helps.
Posted on Aug 26, 2011
Anonymous
SOURCE: How do,I install pyle PLCM25 backup camera?
I just want to know where does the black and red wires go that r on the camera
Posted on Sep 26, 2011
When I power up the unit, the camera is displayed immediately, the backup wire turns the screen off.
There's a wire in the head unit harness that's meant to be connected to the vehicle's reverse light wire. If you don't have a rear view camera, this wire should not be connected to anything.
2helpful
I have just install a rear view camera and monitor,it comes on when i put car in reverse but as soon as i touch the foot brake the monitor shuts of,why does it do this?
It sounds like you connected to the conductor (wire) that controls the actuator that locks out shifting the transmission which is then disabled when you actuate the brake.
Please provide the model of the car and video system; I may be able to get an electrical schematic and trace out the signals.
1helpful
How can I get the install instructions for PYLE PL7300BT Rear View camera system?
Pyle PLCM7300BT Mobile Video Navigations Back up Camera Rear View...
Went to this site to find your particular product,it has a downloadable pdf manual whic will by default show you your setup.You may not have the green wire but if you read this manual you may be able to by process of elimination figure out your question.Pyle also has a very good technical support staff,been there done that ,they will also help you out.Good luck hope this helps you.
Installation instructions for pyle view plcm7200
Where do I hook up the green wire on Pyle 7200 rear view camera
Pyle plcm7300bt what does the green wire reverse car wire connect to + or ground
The green wire connects to the backup lights control. When the gear shift is in "Reverse" this acts as the switch on the "Monitor" and turns the system on so you can see what's behind you to safely "Backup" Hope this helps you.
2answers
What to do with the second camera wire? Video connection and...? Pyle PLCM 7200
This is not a solution. I have the same question. In addition, my unit shows blue screen and "no signal". Any guesses?
2helpful
The problem is everytime i turn my head lights on the pyle swiches to a blue screen, the radio goes off and it has the words "car" in the top left corner of the blue screen. i own a 2004 ford...
you have your wiring wrong, im guessing you have a rear view camera on there, you need to dissconnect the wire thats for the rear view camera (behind ur dvd) get another wire , connect one end to your backup lights (12v, red) and connect the other one to the wire for the camera behind ur dvd player
Video Cameras Logo
Top Video Cameras Experts
Ekse
Harrie
Are you a Video Camera Expert? Answer questions, earn points and help others
