Question about Logitech Z-2300 Computer Speakers
My logitech z 2300 subwoofer is not producing sound
The speakers work but not the subwoofer, it was woking fine but is suddenly not making noise at all. all of the wires are connected correctly
Posted by pnw5000 on
Mark Sandlin
    Novelist:
  • 92 Answers
Since this set is hardwired together and the other speakers are working, the only easy fix would be the subwoofer got turned down on the remote volume control. Anything more would mean its broken. If its under warranty take it back. If its not and you know somebody capable, you might have them check for the obvious,bad solder connections on speaker, or and open voice coil on the speaker it self.
Posted on Aug 26, 2009
1helpful
Logitech z-2300 subwoofer not working
ahh logitech always the sub that goes. its buggered but dont toss out the whole speaker set just buy another one and youl have spare speakers when you need them
2answers
Speakers dead
check for individual speaker resistance. or in the dividing network for some burn fuse or coil.
Logitech Z-2300 subwoofer/Bass volume cannot completely shutoff
Make sure the wired remote is connected completely and if that doesn't work try putting a pillow or a pile of blankets to cover both the subwoofer driver and the air port on it and that should reduce the sound coming from it. Also if it is in a corner or on a solid floor like wood or tile i would move it to a less enclosed space with carpet or a rug. Thats all I got I hope that helps.
1helpful
2answers
Logitech THX Z-2300 only one speaker works. theres something wrong with the input. both speakers work fine but the 1 of the inputs on the subwoofer stopped working, causing only one speaker 2 work
try tapping the speaker box in your palm while the speaker is connected. There might be a bad contact of the wires inside. I had to open up my speaker to find that out. i moved around the wires connected to the cone of the speaker and then started to hear music once i did that. it was the left speaker by the way.
4helpful
5answers
Logitech THX Z-2300 Speakers Don't work and subwoofer does
Well, just because someone at Logitech said the speakers are definitely broken doesn't necessarily make it so. They told me the same thing, yet when I read on another forum that plugging earphones into the wired remote sometimes seems to make things better, I plugged earphones into the wired remote -- and Voila! All of a sudden the blue light went on and I had sound from all three speakers. The sound continued working properly even after removing the earphone jack. IMO the problem could be with the wired remote rather than with the speakers themselves. My speakers work again!
Logitech z2300.
Make sure you you have turned on both of the power buttons the one on the remote should be pushed down and there is also one on the back of the subwoofer just above the power cord connection. Hope that helps if not just let me know
Logitech Z-2300 speakers
maybe the first step could be checking the subwoofer's fuse.it is located over the power supply connector.
Logitech Z-2300 computer speakers
Please recheck the connection of subwoffer once again..
thankyou...
Logitech Z-2300 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Ekse
 Francisco Mauricio...
Mandeep  Singh
Mandeep Singh
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
