Question about Lands Phones
How do I record answering message on el51209?
Posted by John Mitchell on
Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Teleph
If your Phone service is recording messages, that disconnects your line. You need to have them turn that feature off, OR set the answering machine to answer is less rings, say two or three. If the FAX machine listens to the line, it can still be set at a higher amount of rings, say four, and should still answer any FAX signal as it's sent to the answering machine.
Jan 25, 2015 | AT&T Lands Phones
How do i set the answering system on a uniden 1580-3 phone, mine is just background noise on the answering machine when someone calls in to leave a message
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
http://www.uniden.com/pdf/DECT1580-3om.pdf
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
Jun 15, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
How do i record my own message
Recording Outgoing Messages:
1. Hold the ANNC-DAYand speak clearly into the microphone.
2. Release the ANNC-DAY when you finish. Your answering machine beeps and automatically plays back your recorded message.
Message limit:
60 seconds
To re-activate pre-recorded message:
Press "delete" during while playing your outgoing message. The pre-recorded message is now activated.
Feb 21, 2011 | Radio Shack (43-3829) Digital Answering...
How do you set up the message for the answering machine? Lost the instructions that came with the unit. I know the phone has a menu, but not sure if this is where I would program the answering machine.
Greeting message
When the unit answers a call, callers
are greeted by a greeting message. You
can record your own greeting message
or use a prerecorded greeting
message.
Recording your greeting
message
You can record your own greeting
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
greeting message is used.
1 {MENU}
2 {V}/{^}: “Answering device” i
{OK}
3 {V}/{^}: “Record greeting” i
{OK}
4 After the handset beeps, speak
clearly about 20 cm (8 inches) away
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
Using a prerecorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a
prerecorded greeting message for
callers and ask them to leave
messages.
Sep 11, 2009 | Panasonic KX-TG1033S Cordless Phone
How do you remove a recorded answering machine message
Settings:
In Settings dialog you can set the following options for Best Answering Machine:
* Greetings - allows setting up the greetings played on pick-up;
* Active in profiles - defines in which profiles the application will pick-up the phone and record messages;
* Storage - allows selecting on which disk the records will be saved;
* Pick up after - sets the time after which the call will be answered;
* Record time - maximum amount of time the message is being recorded;
* Format - message file format (amr,wav);
* Icon - configures the visibility of the icon displaying application activity and presence of new messages; depending on this parameter, can be shown in standby screen only (Phone application) or in any application;
* Play volume - play volume for the greeting;
* Records lifetime - automatically removes old messages;
In this view you can listen to new and old messages, delete unnecessary messages, send the recorded messages and call the person directly from this view.
During the call:
When Answering Machine is processing an incoming call, you will see a dialog showing the application's progress with the ability to stop it:
* Answer - when this command is chosen during a call, it stops greeting playback or message record and you can continue talking to the caller;
* Hang up - stops greeting playback or message recording and terminates the call; hope this will be helpful...
Jun 23, 2009 | Nokia Cell Phones
Panasonic kx-tg2740 cordless phone - how to change message?
  • Step 1Begin the recording process by first locating the "Change" button on your answering machine. This button initializes the answering machine for adjustments to the settings of the various features.
  • Step 2:Locate the microphone on your answering machine and lean towards it until you are about nine inches away.
  • Step 3:Locate the "Annc" button. Press and hold the "Annc" button until it beeps. Begin recording your message.
  • Step 4:Watch the message window while you are recording your message. It keeps track of how much time has elapsed since you began recording. You can record a message that is up to three minutes long.
  • Step 5:Locate the "Stop" button and press it when you have finished recording your message. The answering machine will play your message back at this point. If you are not satisfied with your message, repeat the steps to record it again.
  • Step 6:Press "Annc" if you want to listen to your message again.
i found this i hope it helps
Jan 10, 2009 | Panasonic KX-TG2740 Cordless Phone
The pre recorded message on the answering machine has been lost.
I read thru the manual. There is nothing bout recovery of factory messages. If you recorded your own, try deleting it. Or unplug the base from power and try a reset. This is from the manual. At the end, I gave you a link to the manual!
Using a pre-recorded greeting
message
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
http://service.us.panasonic.com/OPERMANPDF/KXTG9331.PDF
Nov 21, 2008 | Panasonic KX-TG9331T Cordless Phone
Radio shack 43-3829 answering machine
Well, your machine might be broken, or you haven't set the little switch on the unit to ANS. The switch is on the side of the machine where the cables come out. But here are the instructions from the manual:
Your answering machine has a built-in outgoing message, "Hello, please leave a message after the tone." You can use this message or record your own.
1. Hold the ANNC/DAY/<<, and speak clearly into the microphone, no more than 10 inches away.
2. Release the ANNC/DAY/<< when you finish. Your answering machine beeps and automatically plays back your recorded message.
*Your outgoing message must be between one and 60 seconds.
*If you record your won message but wish to revert to the pre-recorded message, press DELETE during playback of your outgoing message.
Nov 09, 2008 | Radio Shack 3825 Answering Machine
Lands Phones Logo
119 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
