Question about Asko Washing Machines
My ASKO 20004 that has worked flawlessly since 1996. Today the display panel went dark, the washer seems to be stuck in the middle of the wash cycle. Never empties, never progresses. Bad fuse? Advice?
    Top Expert:
  • Asko Master
  • 66,560 Answers
CONTROL BOARDS DO FAIL CALL A LOCAL REPAIR SERVICE OR BUY A NEW WASHER
Posted on Jul 09, 2019
5 Suggested Answers
Anonymous
SOURCE: asko t760 display panel
My Asko T761 had the same problem, power button lights up but the LCD panel if off. This is not the fuse becuase I replaced with "new fuse replacement kit" provide by Asko but this did not solve my problem. All I needed to do was press the "reset button".
Posted on Jul 26, 2008
Anonymous
SOURCE: repair front load washer
wash machine not draining properly at end of wash. not fully spinning.
pls advise
Posted on Sep 11, 2008
Anonymous
SOURCE: hi,i have an indesit wil
sounds like motor carbon brushes need replaced .
pete.
Posted on Sep 25, 2008
Anonymous
SOURCE: Asko Washer/Dryer (WCAM 1812); Dryer not working.
Update: The dry cycle is now working! Apparently the automatic overload/shut off on the heating element got tripped. We had a technician out this morning. He unplugged the machine, removed the top of the unit, and simply pushed a little red/orange button that was on top of the heating element. When we plugged it back in the heating element worked again. The technician was able to troubleshoot this by checking the amps while running the dry cycle. But the proof was really when we did a load and the machine heated up (just like it used to) during the dry cycle. This was actually a relatively simply fix - though could be dangerous as you have to open up the electrical area. The reset button is rather inconspicuous and located on top of the heating element, which is long (runs front to back in the center part of the top of the machine - which you can get to by removing the lid/top outer housing) and silver - wrapped in insulation. It's pretty obvious. The button is in a little metal fixture on top of the heating element. The technician told us that the rest can get tripped when the unit overheats. (We think this happened when the laundry tub overfilled and the hose was totally submerged - the machine was working overtime to pump out the water.) The technician also warned that this can happen if the machine gets turned off suddenly mid-cycle - especially during the drying cycle. He said that the heating element gets so hot, it needs to have a gentle cool down period, which is marked on the dryer dial for the last 20 minutes of the cycle. I hope this helps others!
Posted on Dec 02, 2009
adrian halligan
  • 1075 Answers
SOURCE: Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Posted on Jun 29, 2010
Asko cylinda ab
Relay fault in the washing machine maybe?
Jan 10, 2014 | Dryers
Dishwasher has stuck on wash cycle asko
Possible that the control panel is faulty and has errors. You can switch off the machine for sometime and if the fault repeats then it can be due to memory problems in the board.
check the filter on the washer. click on: Washer maintenance
Jan 24, 2013 | Asko D3122XL 24 in Builtin Dishwasher
My Asko 20004 washer has been running perfectly since November 1, 1996. On Friday, while washing a load, the washer suddenly stopped. No power, on-off switch did nothing and I checked the house fuses and...
Hello Rick,
Welcome to FixYa.
There are 2 internal fuses for the Asko washer, on the 20004 model they are located at the back next to the power cord...
i.e.
To remove and check the fuses you`ll need a flat/slotted screwdriver and place it in the slot of the fuse holder and turn them left 1/4 turn and pull out.
**The above is an image for removing the dryer fuse, but the same procedure applies**
Once removed this is what you should see...
I would also suggest removing the top of the washer to visually inspect the condition of the wires as a poor connection can cause the fuses to blow.
i.e.
The replacement part is a 240v 15 amp slow blow fuse. part number will be as listed below and it is a complete kit available at "repairclinic.com"
# 1460992
Hope that answers your question or better yet solves the problem altogether.
Thanks for choosing FixYa and good luck. Please take a moment to rate the info provided and a short testimony if you will its warranted.
Regards,
Macmarkus :)
Oct 17, 2010 | Asko Washing Machines
Gives me an OE on the display
It's the pump motor -Plug your machine and run a test cycle and check for some grinding noise. Pulled the pump out from under the washer instead of taking the whole thing apart much, much easier.
Apr 10, 2010 | Asko WL6511W Front Load Washer
Asko washer 20004 stopped mid cycle, water is
Do not play with water and 240volts or 120 volts....it is a LETHAL cocktail.
Get a techo to save you the headache and possibly YOUR LIFE!
Oct 19, 2009 | Washing Machines
Asko 620 washing machine keeps filling
Sounds like your fill solenoid has stuck in the open position. There are 3 #20 Torx fittings along the back and you can lift off the top panel. The solenoid will be in the back left side.
I would shut off your house water supply to the machine and then do a voltage check to see if the solenoid is remaining energized. Another more simple option is to give the device a few light taps as some debris may have become trapped inside and caused it to become stuck open.
Jul 07, 2008 | Asko W620
Aeg 72630 update will not rinse during rinse cycle
if is an asko remove the top panel and check the triple valve for a faulty solenoid,also remove paddle from inside the drum with a screwdriver in the middle hole and pull toward you,and look inside the black sump hose to see if theres a plastic ball in the hose if so you need to remove it take of front panel/s to get access to the hose.also check for coins in the hoses acting like a valve.let me know and i will think of somthing else
Mar 25, 2008 | Asko W6761 Front Load Washer
Washer stops in middle of cycle,
Junk it! Cut you losses now. I had a Calypso for 6 years and went through 3 pumps, various circuit boards , a drive motor ,etc..... not to mention the down time of not having a washer in a 4 person household. We bought a Whirlpool Duet HT 9200. Clean , fresh laundry not all balled up anymore. Junk it. You'll thank me.
Nov 01, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Asko washer 20004
where does the leak appear at?
Sep 17, 2007 | Asko W6441 Front Load Washer
Washing Machines Logo
75 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
ROB
Lollo Pop
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
