Question about Furniture
How do i find the model number of my Koolspace wine cooler ? Also how do I change the light bulb in my Koolspace wine cooler ?
Posted by dennis English on
5 Related Answers
bobotfel
Felizardo Erilla
  • 241 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
sanjar57
SOURCE: My Koolspace cooler in my VK250 wine fridge quit cooling
I have the same problem with mine and have tried the same things as you have. I took my unit to a air conditioner service place and they said these units are not worth fixing. It would cost about $150 to add a valve so they refill the gas and then try to find out why it is leaking. I am about to order another one which makes me vary mad. My unit is 1.5 years old.
Posted on Apr 21, 2008
Timothy Snead
  • 6 Answers
SOURCE: danby wine cooler repair
call Danby at 800 263 2629, you can order parts from them
Posted on May 27, 2008
Anonymous
  • 232 Answers
SOURCE: Koolspace NUVO wine cooler recharge
do you have a recovery machine and gauges you need to tap both sides to check the high to and it needs to be vaccumed down to remove moisture ,find and fix the leak. leaks arnt verry common un less someone broke a line somehow. if the compressor is running it is more likley it has a restriction or bad valve in compressor, hooking to high and low sides will determine which if is less than 5 years old it could be under warrant still most sealed systems have a longer warranty than the rest of it is the evaperator getting cold at all.
Posted on Dec 31, 2009
Anonymous
SOURCE: MC wine cooler MCWC44DZ error code e3
I had an E3 on the upper zone. This fix was simple. Unscrew the 2 screws for the middle tray. Pull tray out as far as you can. Check the wires in the back, those are the wires for the fans in the back. The connectors over time corrode, and break off... All I did was connected the 2 wires that had broken off of their connector directly to eachother. E3 went away and the cooler is working as it should now.in
Posted on Feb 17, 2010
Pressure for wine cooler
used the wrong freon firstly it should be r 22 r137a is for automobiles/trucks only
Aug 28, 2016 | Vintage Keeper Koolspace Wine Cellar
How to set Drobot controls?
PRESS AND HOLD THE SET BUTTON WHILE YOU CHANGE THE SET COOL POINT UP OR DOWN
Aug 05, 2012 | Vintage Keeper Koolspace Wine Cellar
How to tell the year of a koolspace wine cooler
That will always depend on the Manufacture of your Koolspace Wine Cooler. If Koolspace keeps record's they will ask you for your serial number. It does appear you have an eliete model and brand name so I would think they are well ahead of the game.
Fax: 403-283-6111
Calgary Phone: (403) 283-7575
Toll-Free: (877) 283-7575
Design/Construction Inquiry: Click Here
Wine Cellar Services Inquiry: Click Here
Accounting Inquiry: Click Here
Cellar Coordinator Inquiry: Click Here
Gallery
If you have warranty issues with your cooling unit (ChillR or Vintage Keeper Nuvo), please contact the manufacturer directly at www.wineracking.com or 1-888-274-8813
We have set up our Calgary space to introduce you to the most stylish and sensible storage and lifestyle accessories for the discerning wine-enthusiast.
Please feel free to drop by our showroom at any time during regular business hours. If you prefer we can arrange practically any time that is convenient for you.
10:00 am - 5:00 pm : Mon - Fri
Saturdays by appointment only
If this was a Whirlpool question I could find it myself with model and serial If helpful please rate this solution, Thank You, Sea Beeze
Nov 24, 2011 | Refrigerators
Cannot get temperature below 65F. Probably need replacement cooler unit. Model: AZMN HAL Odyssey Approx Size: 9" H x 15.5" W x 14" D. Serial #: AA4-Odyssey-01201-121
I have never heard of a wine cabinet getting below that range? Has this unit every reach temps that low before? I would make sure the unit is breathing, check the condenser and air flow through the unit. If the unit is not choking, and temps can go below 65, than yes you will need to have it serviced. It can be a thermostat issue.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 13, 2011 | Vintage Keeper Koolspace Wine Cellar
Dec 31, 2009 | Vintage Keeper Koolspace Wine Cellar
Koolspace 600 Problem
You'll need to replace the fan. The original fan bearings wear our after a couple of years. It's pretty simple to drill out the rivets and replace the fan. I suggest you replace all four with ball-bearing fan units.
Sep 19, 2008 | Vintage Keeper Koolspace Wine Cellar
Moaning & groaning noise
your koolspace is loosing refrigerant slowly. the solution is to buy another one, because koolspace people changing their design every year so you as a consumer would not repair the cooler rather buy one new from them. what a sad way to do business. so do yourself an act of kind, do not buy koolspace, buy another brand and modify the hole to fit it in.
joe
Nov 25, 2007 | Vintage Keeper Koolspace Wine Cellar
Furniture Logo
182 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
