Question about Lite On Computers & Internet
I have a zipspin c120 pro, the Lite-on ihap 122 drive is bad, will a ihap 124 by lite on work in its place?
Posted by John Rolls on
Glenn
    Master:
  • Lite On Master
  • 591 Answers
Yes. DVD drives are intercompatable for the most part.these days. just pull out the old one, install the new one, and the OS will install the drivers and it will work just fine.
Posted on Jul 11, 2019
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: I am trying to replace 3 cdrw burners in a 1 to 7 cd duplicator
this should work, put new cables ok
jeff 0403960527
Posted on Feb 16, 2009
Robert Debison
  • 412 Answers
SOURCE: no spedo abs lite on brake lite on engine lite on
you to have scanned and check abs controller for fault codes..sounds like rear abs sensor mounted in rear diff
Posted on May 21, 2009
Anonymous
  • 4 Answers
SOURCE: my ds lite touchscreen doesn't work!
ur ds has to be used with a pen or the screen will be broken
Posted on Jun 20, 2009
Anonymous
  • 11 Answers
SOURCE: four wheel drive lite is blinking and wont go out
Hi, You will need to take to mitsubishi dealer and have them scan your diagnostics. But this is a common thing in montero's and it sounds like o ring (which is plastic) in transfer case has busted. As long as it switches in and out of 4 wheel drive it is ok to drive. If it doesn't, dont drive it...it could cause alot of damage.
Posted on Aug 04, 2009
Anonymous
  • 1985 Answers
SOURCE: 4 wheel drive wont work . lite blinks lite flashes
under the hood ,in the center of the fire wall is the relay that sound bad
Posted on Nov 26, 2009
Daemon tools lite cd key
Dear ghinea_denys, Daemon Tools Lite doesn't need any CD key if used for non-commercial use. It can be installed both as a Shareware and a Freeware. While you are using it for Commercial Use you have to activate the Paid License, and in that case you must provide it with a License Key. To use it for personal and non-commercial work, you should activate the Free License, which will help you install Daemon Tools Lite to your computer without any CD key.
You can download the latest Daemon Tools Lite 4.41.3 from the link below:
http://www.daemon-tools.cc/
N.B. : License key is also needed for using Daemon Tools Pro as full version.
Hope this helps,
Regards,
Mrityunjay.
Aug 05, 2011 | Computers & Internet
WHAT IS THE MEAN DEVIATION FOR 121 122 123 124 125 126?
Hello Dear
Mean deviation is calculated by the following steps:
1. Add all the numbers and then divide by total number of values. That is take a mean.
2. Then subtract the mean from each values and ADD them all
3. then the added answer must be divided by the total number of values. and you get the Mean devaition.
I solved your problem here in steps:
Step 1:
(121+122+123+124+125+126) / 6 Equals to 102.6
Step 2:
(121-102.6) + (122-102.6) ...... +(126-102.6)
=125.4
Step 3:
125.4/6 = 20.9 is the MEAN DEVIATION
Hope so this will help you.
Please dont forget to rate the solution.
regards
Mar 12, 2011 | Health & Beauty
When I install a movie or game, message states need to install disc or no disc recognized
likely your drive cable is bad or the drive is bad. restart your machine and load bios and see if its shows up in your bios.fi it does your drive is working. and it could be the disc.
Mar 23, 2010 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
Nov 25, 2009 | Chevrolet Blazer Cars & Trucks
When I turn on LG 1888H dvd recorder, it just says please wait but nothing happens. Can it be a HD problem?
Your DVD loader (DVD player) has some kind of malfunction. (dirty lens, bad build, etc...)
Just stick a new PC IDE DVD player in it and it will start working. I had the same problem.
I used a lite on made in 2004 and the RH1888 works prefect, but does not look perfect. The drive is won't work in conjunction with a it's original face panel.
I blue tacked the display on the top of the chassis, and got the big ol' lite-on drive sticking out front, but it works perfectly.
Good Luck!
-Pro Hack
Apr 29, 2008 | LG Televison & Video
Replacing batteries on a Tripp Lite Smart 2200
hi there
tripp lite includes battery replacements and they have authorized sellers and distributors. however, they dont sell directly to consumers like us. they do have sales and support if you want someone from them to have the battery replacements installed
call there Customer Support (773) 869-1234
or visit there online site for more details.
http://tripplite.com/index.cfm?countryid=122
hope this helps.
Feb 07, 2008 | Tripp Lite Battery Finder: SMART2200RMXL2U...
Lite-On LTN486S issues
If you recently uninstalled or removed Easy CD Creator or DirectCD or some other CD-writing software, you might want to check out this article from microsoft http://support.microsoft.com/kb/270008/
Dec 05, 2007 | Lite On (LTN486S) Internal 48x CD-ROM...
Lite On LH-18A1P DVD RW
I have two LITE-ON DVD DRW LH-18A1P on drive (E:) and drive (F:) It has gone from everything working great to not being able to burn a DVD. When placing a DVD into either (E:) or (F:) it shows up in my Window's Explorer as a CD drive.... Only allowing me to burn a CD in these drives.... Can play past burnt DVD's though in both both drives.... hve tried a couple of different brand disc, LG and TDK and get the same message appears 'to please insert a dics', need help I do!!! lcs2
Running Window's XP
DVDMy LITE-ON DVD DRW LH-18A1P
Oct 09, 2007 | Lite On LH-18A1P DVD RW Dual Layer Burner
Computers & Internet Logo
Top Lite On Computers & Internet Experts
Vernon Taylor
ray gallant
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
