You will also have an issue with the voltage which is 110 volts in the US, and 240 volts in the UK. Without a suitable voltage dropper, you will wreck it.
Only if they use the same system
PAL (European)
NTSC North American.
UK uses PAL, Canada uses NTSC
So to answer your question: No it will not work.
SOURCE: my player doent accept dvd disc from canada
Your player doesnt play a dvd disc in canada this could be because of region limitations and your remote control has nothing to do with this problem try replacing with new pair of batteries and try again.
Thankyou
SOURCE: I just purchase a sylvania
there's a section in the book that talk about audio you have to set the blu-ray on the right setting for the sound to go to your speaker. hope you can do it i had the same problem with mine. pierre
SOURCE: Sony potable DVD player can not read DVD now
Dust has settled on the lens,. Clean it with q-tip and be very gentle.
SOURCE: BUY A REMOTE CONTROL FOR
Please check on the link for a suitable model:
http://www.espares.co.uk/search/remote-controls/p/1090
