Question about Coffee Makers & Espresso Machines
Bought a D?Longhi Bar 32 espresso maker at an estate sale. It’s in good condition; it makes coffee & steams milk ok. The problem is, after making coffee, it continues pushing steam out from the coffee dripping area, even when I’m steaming milk. It’s a real mess & wastes a lot of water. Any ideas on how to stop the steam venting from the coffee dripping area post-use?
Posted by Jeanne on
5 Related Answers
Pierre Laplante
  • 2042 Answers
SOURCE: Coffee tastes burnt/No steam for froth
so i guess our expresso you dont have that creamy topping that lack pressure descalcify not with vinegar remove caicium in chunks have a chance of blocking everything descalcifier solution melt the calcium 1part solution 1 part water fill the water with solution open the valve if some come out close it leave the solution in it for 15 minute repeat untill empty rinse very good cheers
Posted on Feb 03, 2008
freetek
Steve Allison
  • 5569 Answers
SOURCE: GE coffee maker model # 169164 making too much steam, not coffee
If you look at the bottom, you'll probably find 'China' on it.
The problem you are having normally doesn't show up for a couple of months after the lime has had a chance to roughen the ball in the check valve that makes up the pump. Your pump isn't pumping.
I suspect you have some particulate matter that has made its way to the primitive check valve and the ball is not moving freely as it should. The copious amount of steam you are getting is from the bit of water that makes it to the heating element before the (yet to fail) thermal switch that cycles the heater element.
If you have a clean turkey baster, you may be able to flush whatever crud there is in the water path through to the outlet over the coffee basket by sticking the tip into the water chamber's exit hole. We have a large veterinarian's hypodermic that does the job nicely when it is time to flush it again and soaking the water path with vinegar every few weeks overnight will help keep it pumping properly too.
If the flushing doesn't work, take it back before GE gets completely out of the appliance business.
(Whatever happened to Silex??)
Posted on Sep 28, 2008
Anonymous
I don't know about the burning business but I had the same problem with the steam wand. the first thing I did to solve this problem was to take small object like a needle or safety pen and insert it into the base of the steam wand. (I have feeling that most problems related to the steaming wand are due to deposits clogging the wand itself.) After I cleared out as best I could I used vinegar and water to help remove any calcium deposits. Sure enough, after inserting the needle into the wand steam began to flow again.
Posted on Nov 02, 2008
Anonymous
SOURCE: Steam leak in GB Mia Espresso Coffee maker
I had the same trouble before and probable causes were:
too much coffee powder in the funnel?
or
the coffee beans are ground
too much, makes the power clogging in the bottom of the steam tube?
Posted on Dec 29, 2008
Anonymous
  • 14 Answers
SOURCE: espresso does not make
Does the water stop while the pump is still operating ? Is the "READY" light ON when the water stops ? You need to be more specific about exactly what the symptoms are because these machines are fairly complex and have pressure and temperature sensors to make sure the shots are consistently good. You should make sure to flush your machine regularly with descaler because scale buildup is the most common problem that you'll run into with coffee machines. You can get descaler at any decent hardware store or you can also use "CLR" which works just as well. If the pump keeps running and the water flow just stops, then I would suspect that there is a clogged line or the grind is too fine. Try pouring a shot without using the spoon to see if the water flows freely. If it flows OK, then your grind is probably the problem. If it still does not flow freely, descale the machine several times and see if that makes things better. If you've never descaled your machine, then use a strong descaler or CLR concentration and run the descaling liquid through the machine several times, or even let the descaler sit and soak the inner workings overnight, If the just pump stops prematurely during a shot, then there is probably a sensor problem with the machine. Take it in to a repair place for diagnosis. If you can't find a place that repairs espresso machines, ask the manager of your local Starbucks what repair company they use, since Starbucks stores have contracts with people to routinely service and repair their own equipment.
Posted on Jun 29, 2009
I have just bought a delonghi ec220cd coffee maker - a replacement for the delonghi ec270 which started to leak badly. However, the milk doesn't seem to want to froth - just wet and may as well just pour...
Try removing the plastic steaming sleeve and just use the stainless pipe. Keep the pipe just below the surface to make the ffroth, then go lower to heat the milk to a max of 165F.
Apr 27, 2011 | Coffee Makers & Espresso Machines
My mum gave me de longhi expresso machine 3yrs old today with no instructions i dont know how to use it were milk goes what coffee to use where water goes how to clean it etc could you help please
I am not sure of that particular model but most do not store milk... You use the steam generator to steam through the milk, held in a separate container. Since you are new at this, get into the habit of cleaning it regularly as without cleaning everything can clog. When you buy coffee start out with a "dark roast" and build your way to an espresso blend, usually the darker the coffee the oilier the bean and hence cleaning gets more important. If you grind the coffee beans yourself use the finest grind available. And enjoy the coffee!
Feb 09, 2011 | DeLonghi Espresso and Drip Coffee IFD
Jura capressa F7 steam milk problem
You should decalcify, when you steam the milk some what gets through to the steam and the build up of these minerals causes the issue
Aug 11, 2009 | Jura Capresso C1000 Espresso & Coffee...
How do I make cappuchino cofee?
If you are looking for a manual, you can contact Jura Capresso directly. If you are just looking for directions for making a cappuccino in general:
Brew the espresso.
Use the steam wand/frothing element and a pre-chilled frothing pitcher (the pre-chilling is optional, but it is considered good form) to steam about 1/4 to 1/2 cup of milk.
A true cappuccino does not involve pouring all of the milk directly into the espresso - you would use a spoon to take about two spoonfuls of the top of the steamed milk and place it on top of the espresso.
You can sprinkle cinnamon, use a cinammon stirring stick, or pour cinnamon cappuccino flavoring on top of the cappuccino for good form (but this part is optional).
Enjoy!
-Tha Mp3 Doctor
Mar 22, 2009 | Jura Capresso CapressoBAR 351 Coffee...
Steam does not come out of steam pipe
If you wait too long after making the coffee, you will not have enough water left to make steam. Try to steam the milk immediatels after the coffee loses pressure.
Jan 16, 2009 | Spidem Divina De Luxe Espresso & Coffee...
Cant steam milk and brew expresso at the same time.
You are not doing anything wrong.. that's the way this uint works.
Jan 14, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Sep 12, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Steam generator
hard water build up in steamer tubes a good clean with clr should help remedy this make sure maker is completly cleaned after using clr cleaner
May 15, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Steam nozzle
For the coffee - make sure the machine has heated up for at least 10 minutes. I've found the grind is the most important in getting a good shot of espresso with a good crema.
It takes trying different grinds to find what works best. When we grind at the store we choose the second finest grind from the finest - we put it to Turkish and then turn it back one notch.
On the steaming side - it takes practice. Sometimes I get froth, sometimes - I usually let the wand go near the bottom of the steaming cup and heat the milk to 160 deg. f.
Apr 06, 2008 | Rancilio Silvia Espresso Machine
Coffee Makers & Espresso Machines Logo
116 people viewed this question
Top Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Ross Keen
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
