Computers & Internet Logo
Posted on Aug 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to bypass admin password
I just got second hand computer its from a big company so it has admin password on it .ive tried taking battery out it dosnt work .can anyone hellp
savageinjun
Level 2:
Scholar:
  • Expert 109 Answers
  • Posted on Aug 25, 2009
savageinjun
Expert
Level 2:
Scholar:
Answers
109
Questions
0
Helped
24592
Points
280
I'm not sure if i've read this correctly...you got a second hand comp from a BIG company that still has a password protected system ??? from my experience..the comp is always cleaned of sensitive data....i'm not going to help you.
Anonymous
Level 2:
  • Expert 68 Answers
Anonymous
Expert
Level 2:
Answers
68
Questions
Helped
24007
Points
190
The battery needs to be out for 30+mins.
Also, during this time, move the CMOS Jumper to the next location, then back into place before restarting the machine (Depending on your motherboard.)
Refer to your Motherboard Manual or Find the manual@ the motherboard manufacturer.
Inside the manual, there is troubleshooting steps you may take to complete this step.
Alun Cox
Level 3:
President:
  • Master 2,679 Answers
Alun Cox
Master
Level 3:
President:
Answers
2679
Questions
0
Helped
689747
Points
8444
You will need to reinstall theOS
1helpful
Change c352 admin password
Mr. Gates, yes there is away to change the pw recommended you get a tech out to do it. Change admin pw not over the internet. Should have a paper work to back it up. Big time security thing Hard drive access and stuff
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
tip
How to bypass Windows XP password? We often meet the headache stuff that don't...
How to bypass Windows XP password? We often meet the headache stuff that don't know the Windows system password at the critical comment. How to do if you made a Windows XP password that you never be care of it? How should you do when your computer has parents controlled by the XP Administrator password? Or you need to borrow a friend's computer to carry out emergency work, but you don't know the admin password...Let's share some tips about how to bypass windows XP password.
First things first, try the guest account. Simply enter 'Guest' in the user name box, or click on the account labeled Guest. Sometimes people will have these account enabled without even realizing it, and many times they are left without a password. If this doesn't work for you, or you require a little bit more access than the Guest account provides, read on.
Next up is Windows XP's built in 'Administrator' account. This account is created during Windows installation, and is not accessible under normal circumstances. Many computers, especially those that come from Dell or similar companies, leave the Administrator account without password protection.
To get to this account, boot the computer into safe mode. You can do this by holding down the F8 key during startup, and selecting Safe Mode from the Windows boot menu. Once the computer boots into Safe Mode, you'll have access to the Administrator account. Things will look a little weird in Safe Mode, but don't worry, things will be fine when you boot normally again.
Once Windows finishes booting, try getting into the Administrator account, leaving the password field blank. If you're unable to get in this way, then there is a password on the account, and unless you can guess it, you're going to have to try something else, and you can skip the next paragraph. If you're in, then there's no limit to what you can do.
Besides, you can also take use of Windows password reset CD to remove Windows XP password if you forgot Windows XP password. Well, how can you get Windows password reset CD? Just download Windows Password Unlocker and a blank CD, you can DIY a Windows password reset CD in 4 steps.
In fact, Windows Password Unlocker can be used to bypass windows 7 password, bypass windows vista password , bypass windows NT password and so on.
on Mar 16, 2010 • Computers & Internet
Belkin password
All most everyone uses a user name of Admin or admin and the password is admin or password.
Hi, I have this ZyXEL P-320 v2 router from a friend. I am trying to set a password on it but it wont recognize the username/password i am using, ive tried everything, admin/1234, (none)/1234, admin/admin,...
It looks like the device was reset from the defaults which you tried already. Did you do the "30-30-30" reset?
Try the 30-30-30 reset as follows:
  1. When router is powered on, press the reset button and hold for 30 seconds. (Use a paper clip or something sharp)
  2. While holding the reset button pressed, unplug the power of the router and hold the reset button for 30 seconds
  3. While still holding the reset button down, turn on the power to the unit again and hold for another 30 seconds.
This process usually works for resetting any router to it's factory setting.
If the device doesn't reset following this, then you're looking at hacking the device physically.
2answers
Just hooked up a d-link di-624 after it sat in a closet for over a year, i can't remember the admin name or password, is there a way to reset it or bypass it, i don't have the disk anymore
there is a way you might have to type it in google or call the company that it was made from if not try holding the button that will reset it but you have to configure the settings again
Ive got a g4 tower plus installation discs but do not know the local admin pass word as i bought it second hand is there any way for me to reset the computer and passwords ? pls help!
You don't need the admin password to restore a Mac from its installation discs. Insert the disc, then hold down the C key as you are starting up, to boot from the disc instead of the hard drive. Continue with complete restoration of the original machine contents.
1helpful
4answers
I cannot set password
There are 2 users in this router, 'admin. and 'user', default password is blank. admin can change password of user without having old password, user can change his own password, admin can change password of his own by supplying his old password then new password twice. To log in to this router, default address is http://192.168.0.1 user name admin and password blank. You may now change password from tools menu.
If you forgot user password then log in as admin and change password, If you forgot all password then only way is to reset router from rare pin hole. Pressing reset for 20 seconds.
Password block
if you dont know the password than last option is to reset the unit to company default and than you can login with admin and password admin. To reset it to company default there is reset button behind it so press it by pen point for 5 to 10 secs. So this my resolve your problem
Password not working
There is no way to bypass this... all you can do is reset the router.
On the back you will find a hole with a reset button inside. You have to press it with a writing pen.
Press the button with the pen while unpluging and reattaching the power cable to the router. Continue holding down the reset button for 10-15 seconds after the power is re-applied.
Then you should be able to access the router by 192.168.1.1 and using the user = admin and password = admin.
Password bypass
which OS is ur's?? r u logged in now?
if ur currently logged in user is adminstrator....then create one more admin user..after that login with ur new uesr a/c..then change ur old user psw...
Grand Canyon Tech
Grand Canyon Tech
