Yamaha HTR-5730 Receiver Logo
Anonymous Posted on Aug 25, 2009
Yamaha HTR-5750 no sound when I turn to the DTV/Cable setting
I followed the quick connect guide but still no sound from the receiver when I select the DTV/ Cable setting I get nothing I'm only getting sound from the dvd player when I hook up the audio/ video cables to the multi channel input connections
Frank Fulton
Level 3:
President:
  • Yamaha Master 1,114 Answers
  • Posted on Aug 28, 2009
Frank Fulton
Yamaha Master
Level 3:
President:
Answers
1114
Questions
Helped
502911
Points
3541
If you are not getting sound on "Any" input except "multi channel" you have a bad DSP chip in the receiver.In short, you need a new receiver, it's a 500.00 repair. If you get sound on "All" inputs except "DTV/CBL" You need to get into the main menu of the Yamaha and select audio, toggle to input, then DTV/CBL and select "Auto". If you still do not get audio, it would be due to the version of HDMI software in your receiver. If it's under warranty, Yamaha will update hardware and software for you at N/C. If it's out of warranty, use digital coaxial or optical as your audio input for TV and run your HDMI directly to the TV. (The repair for this too would run 250-350) I hope I've covered all the possibilities. If you need further help, post a comment and I can help you more.
Testimonial: "thanks for the info boss it's greatly appreciated"
1helpful
HTR-5750: How to access menu without remote control?
Unfortunately, you need the remote or a universal remote which matches the original remote to access the menus. The manual for the HTR-5750 is available here: https://usa.yamaha.com/files/download/other_assets/5/319575/HTR_5750_5740.PDF Amazon lists a few vendors with an equivalent remote.
I wish that I had better news for you.
Preamp for yamaha htr
I have a Yamaha HTR 5750 am I able to hook up a power amp to it
My HTR-6060 plays through the tuner and dvd but not the DTV/CBL
Digital settings need to be assigned by the receiver in the ption Menu >> Audio Select.
Check the one for the HDMI from DTV/CBL.
I have the htr-5750 5.1 surround sound yamaha receiver. how do i connect my xbox to it?
You can you optical SPDIF cable - both xbox and your yamaha should support it. If you can't find cheap optical cable in your store, but it from ebay ($1-5 max.)
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
Getting Audio to work with our Cable Tv
The HTR-6130 does not decode the audio from the HDMI inputs. It only acts as a switcher. You will need a separate audio connection from the cable box to the HTR-6130.
1helpful
No video signal on Yamaha HTR 5930
On , HTR-5930, composite inputs are routed only to composite outputs. The same happens to component input. You can't see video from V AUX if your TV is hooked-up on component output. Also, check if you connected correctly GREEN, BLUE AND RED on both receiver and TV SET.
2answers
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
DTV Cable No Sound
Check if DTV/CBL is set receive COAXIAL or OPTICAL inputs. Good luck
3answers
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
