Your car comes with a sealed transmission. It doesn't have a dip stick to check trasmission fluid. Only way to check it is to have someone who works on cars to check it for you or just take it in to the dealership so they can give you the info. Many new cars don't have a transmission dip stick.
Dont forget to rate me please
THERE SHOULD BE A DIP STICK LOCATED UNDER THE HOOD CLEARLY MARKED TRANSMISSION. TO CHECK YOU NEED THE CAR RUNNING IN PARK OR NEUTRAL AND AT OPERATING TEMPERATURE WICH SHOULD BE AROUND 195 DEGREES. IF THE FLUID IS IN THE ADD CROSS SECTION THEN ADD ACCORDINGLY THE FLUID GOES IN THROUGH THE DIP STICK TUBE SO YOU WILL NEED A FUNNEL! GOOD LUCK
there is no dipstick, you can access the transaxle by lifting the car up. It is located on the drivers side right by the wheel. Remove the bolt at the top of the pan, if the fluid dribbles out there is enough, if not you need to fill it.
The transmission oil is located in the transmission. If you are looking for the dip stick, its on the engine and its written on the top of the stick. Do not mistake the oil dip for the transmission dip stick. It sounds as if you need someone to show it to you. Go to your nearest car parts and they will gladly show you the dip stick. I hope this was helpful.
if it is an automatic transmission, the dip stick is under the hood and should be on the drivers side of the engine,start the car leave it in park,pull the dip stick out and wipe it off with a cloth,reinstall the dip stick in the filler tube completely,and remove again and notice where the fluid level is on the dip stick,if you need to add fluid to bring it up to full,the correct fluid for your car is printed on the dip stick,you need a transmission funnel and put in in the tube you pulled the dip stick out of. if you transmission is a standard,there is a 5/8 bolt on the side of the transmission you remove and put something like a screw driver in the hole to see where the fluid level is,.
