Question about Kodak EasyShare C613 Digital Camera
My camera doesn't turn on - Kodak EasyShare C613 Digital Camera
    President:
  • 2,761 Answers
It could be something more serious, or as simple as inserting fresh/fully charged batteries, but the problem you describe is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Posted on Sep 06, 2009
6ya staff
SOURCE:
My display screen doesn't work and the camera turns on but would not turn off
Hello, Sounds like internal malfunction, needs to be checked by service tech.
Dec 16, 2012 | Kodak EASYSHARE M1063 Digital Camera
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
Turned camera on gives error message to turn off and back on again . No matter how many times we turn off and on it won't clear the message. Took battery out.put back in. Message still there. Also len
Camera was probably dropped. Motorized autofocus lens was probably damaged when dropped. It doesn't get more of a big deal than this. Depending on age of camera, it may be a ''wipe-out.''
Ps... I'm saying ''probably'' dropped because I didn't see it happen, but this is precisely what happens when they are dropped. It doesn't take much of a ''jolt'' to do the damage, and there is usually never any external damage.
Oct 09, 2012 | Cameras
Camera doesn't turn on
make sure you take your camera off of lock and put it on standby after turning it on
Sep 26, 2012 | SiPix SP-1300 Digital Camera
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
"connection error" appers on camera
Unplug the usb and turn off the camera attach the usb cable and then turn on the camera. If that doesn't work check canon's website for up to date drivers for your camera.
Jul 30, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
My Canon Powershot SX120is camera was dropped on a high school gym floor. Since then it hasn't turned on. I think the battery connections on the little battery door are damaged, since you can tell...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 25, 2011 | Canon PowerShot SX120 IS Digital Camera
Camera "dead"
Did you try taking the batteries out? If not, try that and then put them back in again. This might reset the camera back to normal. Also, try turning the dial. Make sure it is at the camera setting, then try shutting it off. Further, move the dial to Set-up, and scroll down to the Reset all setting, press the right arrow and answer "Reset".
Sep 18, 2006 | Nikon Coolpix 5600 Digital Camera
Kodak EasyShare C613 Digital Camera Logo
239 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
