Maytag PAV2300 Top Load Washer Logo
Posted on Aug 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Old admiral clothes washer leaks at front - Maytag PAV2300 Top Load Washer
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Aug 25, 2009
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3737697
Points
36075
Troubleshooting Water Leaks
Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.
Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Step 1: Check the lid seal. If faulty, replace with a new gasket.
Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
Step 4: Check the drain hoses. Tighten connections or replace hoses.
Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
Step 6: Check the splash guard. Tighten connections or replace.
Step 7: Check any plastic valve. Tighten connections or replace.
Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
Step 9: Check the water pump, using the procedures that follow.
Just purchased a new Admiral Clothes washer. When
Could you check and see if both the hot and cold hoses hooked to the back of the machine are actually putting out hot and cold water? If they are, it may be time to return the washer to where you bought it and get another. Be blessed.
1helpful
Water is leaking from the bottom of the machine and will not fill up
Your water leak can come from 3 areas:
1) drain hose on back of washer is coming off / splitting / getting loose
2) water pump is leaking (cracked?) or has a gasket that has deteriorated.
3) hose between tub and water pump has come off / split / became loose.
Since your washer isn't able to hold water, it makes it easy to remove the clothes, and lean the washer forward to see what is going on. Most washers' mechanicals can be acessed from either the bottom, or from the back via access panel. The water leaks are generally a pretty easy repair.
1helpful
Sometimes does not spin enough to wring out water from clothes.
The spin cycle should be on a timer,and shouldn't be able to change how long it spins.The same timer that controls all the cycles of your washer.Your pump may be trying to go out,and isn't removing the water fast enough.This will keep water in the tub,and the normal spin cycle isn't long enough to let the pump get the job done.Another problem might be a clog in your drain hose.Another problem could be the drain hose is set to high above the pump,and the pump can't push it up that high (shouldn't be a problem if you are using the hose that came with the washer,and not extending it with another hose or something.)
2helpful
Admiral washer, spins too slow so clothes are still soaked
The clothes being wet and the drum spinning slow are probably due to a worn belt, tilt the machine back and the belt can be removed and replaced from below with no tools.
If the machine is constantly filling with water the level pressure switch requires changing. Isolate the machine, use a knife or thin bladed tool and insert between the front panel and the top panel approx 4" from each side to release the clips, the top should lift up, the pressure switch i at the back LH side, you will see a small pipe attached to it from lower down the drum, replace the pressure switch pull off the terminals and the hose and replace using the same order of connections.
My Admiral Washing Machine (5 years old) is leaking.
Isolate the machine, use a knife or thin bladed tool and insert between the front panel and the top panel approx 4" from each side to release the clips, the top should lift up,2 screws at the top inside will release the front panel for a better view.
Admiral washer is doing a lot of vibrating...it is level
Possibly a worn drive belt on the underside of the machine, causing the drum not to get to full speed, clothes will be wetter after sping plus vibrates heavily - replace belt.
Tilt machine back for access to underside, simply pull belt off and replace, tension is automatic on motor.
1helpful
Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
Admiral Heavy Duty 22lb. 2 speed motor going off balance
Had Same problem. Replaced The 6 retaining springs and snubber.
$15.00 worth of parts.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
