Question about Hansol Computers & Internet
Monitor displaying out of range message - Hansol Computers & Internet
  • 1,511 Answers
Hello and Welcome to FixYa!
This usually happens when you select a resolution or a refresh rate that is beyond the monitor range. For example if your monitor supports a max. resolution of 1024x768 then if you give it a signal of 1600x1200 it will display out of range.
Solution of this problem is to reduce the resolution or refresh rate frequency.
Changing screen resolution in Windows XP: First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
How to Change the Screen Refresh Rate of Your Monitor loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Source:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
http://support.microsoft.com/kb/311403
Kindly rate me if i was helpful.
Regards,
Waqar
Posted on Aug 25, 2009
    New Friend:
I CHANGED THE SCREEN RESOLUTION NOW%2CTHE SCREEN IS SHOWING OUT OF RANGE .PLEASE HELP ME%3F
Posted on Mar 27, 2010
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: e-yama monitor "out of range"
The fix was pretty easy in the end.
Instructions are based upon Windows XP Pro OS.
Re-boot computer but inerrupt start-up by pressing F8 (option will vary between computers)
Select SAFE mode but with VGA option in order that the screen will actually display.
Once fully loaded click:
Start
Control Panel
Display
Settings
Using the mouse cursor adjust Screen Resolution sliding scale until the ratio matches your monitor e.g. 1280 x 1084
Then click Apply and OK (important to do it in this order otherwise changes will not be saved)
Reboot as normal and the monitor should now display correctly.
Posted on May 12, 2009
pravinbhavsa
pravin bhavsar
  • 348 Answers
SOURCE: over range message on monitor
switch on the computer then press F8 F8 contineusly then highlight on safe mode press enter then display will see if you want to work on high resolution then attatch external display card and best will be AGP card then you can watch movie much clear also 3D games
Posted on Nov 25, 2008
Get rid of "Out Of Range" message on e218c1 monitor.
The device driving the monitor is exceeding the horizontal and vertical frequencies that the monitor can display .....thus the "out of range". The specs for this state that the Horizontal Freq. is 80Khz and the Vertical Rate is 75hz. If you are driving this monitor from a computer running Windows, reboot the PC and use the F8 key to put it in SAFE mode. This will cause the video driver to default to a rate that the monitor can handle. Then go into the screen resolution settings and reset them. The native resolution of the monitor is 1680x1050 at 60 Hz. Exceed that and you'll get the "out of range"
Sep 10, 2014 | Envision Peripherals 22"" envision e218c1...
Displaying "out of range" when plugged in
Hello white tiger, hi, the out of range error is usually caused by a very high resolution setup on your computer display card that windows installed (generic driver), the monitor simply cannot produce the resolution, set your resolution to a safe level like 1024 by 768, most monitors can display this resolution. The root of this error message is incorrect display driver, you need CD to install the display driver. Once installed your resolution will now be controlled to a safe settings were the monitor can display properly.
Aug 20, 2010 | Star Logic Monitor
HPL1506 The input signal from pc display foe few seconds and goes off error recommended setting - 1024 x 768 - 60Hz
It can be that your PC video resolution is set higher than 1024 x 768 @60Hz for the monitor to display correctly.
Spec: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00485268&lang=en&cc=us&taskId=101&prodSeriesId=1130384&prodTypeId=382087
Try this per HP:
HP Business Monitors - What Do I Need to Do When the Message Sync out of Range Displays on the Monitor? ISSUE: What do I need to do when the message Sync out of Range displays on the monitor? When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur: Sync out of Range SOLUTION: To avoid the message, lower the resolution or vertical frequency of the video card. Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
  1. Shut down and restart the system. For consumer systems such as HP Pavilion desktop PCs, push the Power button once. For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
  2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
  3. Scroll down to highlight Enable VGA Mode , and press ENTER .
  4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor.
May 20, 2010 | HP L1506 15" LCD Monitor
DELL E153FPf doesn't show the image
OSD Warning Messages A warning message may appear on the screen indicating that the monitor is out of sync range.
Cannot Display This Video Mode
This means that the monitor cannot synchronize with the signal that it is receiving from the computer. Either the signal is too high or too low for the monitor to use. See Specifications for the Horizontal and Vertical frequency ranges addressable by this monitor. Recommended mode is 1024x768 @ 60Hz.
Occasionally, no warning message appears, but the screen is blank. This could also indicate that the monitor is not synchronizing with the computer or the monitor is in a power save mode.
Jan 18, 2010 | Dell E153FPf 15" TFT LCD Flat Panel...
Out of range message
This is caused by a resolution and/or refresh frequency setting in your computer's display properties that exceeds the values supported by the monitor.
Find out the optimum (native) resolution of your monitor (in case of AMV 17V5 it will be 1280x1024 pixels), and supported refresh frequency (usually 60Hz for LCD monitors), and set your display properties to these values.
Nov 23, 2009 | Amptron AMV 17V5 17" LCD Flat Panel...
''Out of range'' message on an older SVA monitor
This usually means the display resolution settings on your PC are set too high for the monitor to display the signal. Try lowering the resolution on your PC.
Mar 16, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Showing message out of range
Your monitor settings within windows are set too high for the monitor to display... When computer first boots.. be ready and press the F8 key...
Enter safe mode.. Reset the display properties in control panel to 800 by 600 for a start. Setting the resolution too high past the monitors ability will give you that message.. Most monitors are able to display 1024 by 768 just fine.. Out of range.. means the display settings within windows are out of the monitors range of ability to display the screen resolution you have set... Good luck!!
Feb 18, 2009 | Dell Dimension 8200 PC Desktop
Out of rang vw193t
Pls temporarily install a older monitor then check the display sttings ,set it to the lowest resolution apply and then check whether its working on the old monitor.Then shut down and connect the new monitor and power on the monitor should work
Jan 24, 2009 | ASUS VW193T Monitor
Over range message on monitor
Nov 25, 2008 | Proview PL926WBi 19" LCD Monitor
Computers & Internet Logo
2,859 people viewed this question
Top Hansol Computers & Internet Experts
Ekse
Gustavo Ortiz
Gustavo Ortiz
Robert Salgado
Robert Salgado
Are you a Hansol Computer and Internet Expert? Answer questions, earn points and help others
