I have a true refrigerator and the lights keep flickering. I have switched out the following:
Light bulbs
Ballast
Plunger adaptors which the bulb connects to
Welse should I check? Are there two ballasts?
Is there a ballast or a starter? if there is a starter (little silver metal or white plastic can), then replace the transformer inside the lamp housing. if there is a ballast (long black rectangle with many wires) and you replaced that and the lamp, then there must be a power drain in the unit somewhere.
Make sure the bulb that you are using can go to that low of temperature.
how would I check for a power drain?
